Question regarding cat removal. - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 40 (permalink) Old 02-02-2010, 04:41 PM
zomething different
r3x1mu5's Avatar
Bike: 07 R6s
Re: Question regarding cat removal.
Originally Posted by kaoss_11 View Post
Wrong the oem headers primaries are smaller than aftermarket headers and the bends are different coming off the head as well.
I ask you this. you have a r6s correct. So if you buy a slip on do you need some form of fuel manageament? ie pc3 pc5 bazz etc
i believe i would be runnin lean, so yes.
...if i don't make it home today, god bless. dot cheers
r3x1mu5 is offline
post #22 of 40 (permalink) Old 02-02-2010, 05:04 PM
lol thats funny for the sake of winning an argument you cant even tell the truth
pm me
kaoss_11 is offline
post #23 of 40 (permalink) Old 02-02-2010, 05:40 PM
Got street appeal?
shnormo's Avatar
Bike: '04 and '07 R6
Images: 1
Send a message via AIM to shnormo
Your bike was mapped at the factory to compromise performance to meet emission and sound laws and regulation. Yes the bike will run with a full exhaust, slip on, what have you with out a PCIII. You don't ABSOLUTELY need it, but it will not be up to its full potential.
A 100% stock bike straight off the show room floor will benefit from a fuel management system. Look at the Power Commander maps, there is a map with different values for a stock bike. The bike runs lean from the factory to meet emissions.
shnormo is offline
post #24 of 40 (permalink) Old 02-02-2010, 05:41 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
in all my years of modding and racing bikes and cars I have never once in my life heard of ill effects from a slip on running w/ a stock header. Correct me if im wrong. Im not here to argue just have a friendly discussion.
so if one bought the mjs and the mjs exhaust your saying they would need a pc for that as well?
Because what I get from what your saying is that the bikes were mapped for stock systems from the factory(obviously no argument there) so that means we would need power commanders for just slip ons then, if what your saying is true. So if what your saying is true than anyone with a slip on essentially needs some form of fuel management? And this is where I disagree.
This is why you see a lot of maps for the 2nd gen R6 with slip-ons..
The 2nd gen has no cat and no honeycombed headers so putting a slip-on on affects the a/f ratio fairly significantly (you can get away with it.. but it's not recommended).
The 3rd gen has the honeycombs and cat built in, so if you ONLY swap out the can, there's not enough change in the system overall to warrant a fuel management system.
dude, he is essentially getting a full system. modified headers with no cat + slip-on exhaust is pretty close to a full system.
if he was just getting a slip on, then there is no need to get a pcv or bazzaz unit.
edit: correct me if i'm wrong
See above
pickpocket293 is offline
post #25 of 40 (permalink) Old 02-02-2010, 05:52 PM
Got street appeal?
shnormo's Avatar
Images: 1
"The 3rd gen has the honeycombs and cat built in, so if you ONLY swap out the can, there's not enough change in the system overall to warrant a fuel management system."
3rd gens run lean too from the factory. Not to mention, most slip on systems remove the Exup valve changing the characteristics of back pressure. So there is a significant change.
Any change will alter your air fuel ratio. It comes down to how much do you care about your air fuel ratio being 14.7:1 Running lean, runs hotter, less life. Running rich, fowling out plugs, clogging said catalytic converter, fouling 02 sensors and excessive carbon build up on the engine internals.
shnormo is offline
post #26 of 40 (permalink) Old 02-02-2010, 06:02 PM
Got street appeal?
shnormo's Avatar
Images: 1
Originally Posted by downsouthsoulja View Post
I just put my 09 R6 in the shop for a custom exhaust installation. We removed the stock exhaust and the bike sounds exactly the same without it cause of that stupid cat. I was told that if I got the cat cut out and a y pipe installed i would need to get a power commander and have it dynoed. My question is this. Would it hurt to run the bike after installation of the new exhaust before getting the power commander or having it dynoed?
Back to the original post, depends on how long and how you run it for dictates IF and to what extent the damage is. Get a fuel management system A.S.A.P!!!
shnormo is offline
post #27 of 40 (permalink) Old 02-02-2010, 06:23 PM
i think some of you missed my point. I know everything you guys are saying is true and correct but I never understood the argument that "whats good for one is bad for another"
pm me
kaoss_11 is offline
post #28 of 40 (permalink) Old 02-02-2010, 06:28 PM
190rwhp......:eek5
jwxfd's Avatar
Bike: 2011 S1000RR, 97 CR500
Send a message via Yahoo to jwxfd
Because the 03-05 and 06-09s models come stock "mapped" without a cat. The 06-10 R6R models come with a cat and honey comb headers, therefore "mapped" for said restrictions. As soon as one removes the cat and honeycombs, the stock mapping gets completely construed, thus causing the motor to run even more lean than from the factory. I.E, ya need to get some type of A/F management system...
On the 03-05 and 06-09s models....no cat....the stock mapping can be used (with very minimal ill effect) when changing around the exhaust system...
Sig courtesy of the man himself: GIjoe007
jwxfd is offline
post #29 of 40 (permalink) Old 02-02-2010, 06:36 PM
Just a dumb racer..
rich0's Avatar
Bike: Supersport R6
What you're totally failing to realise is that stock FOR ANOTHER BIKE is not stock for THIS bike.
Saying that an 03 set of headers are still OEM headers and therefore don't need a map is retarded, they're very different to 06 headers, and therefore need different engine management.
rich0 is offline
post #30 of 40 (permalink) Old 02-02-2010, 07:13 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
You are comparing apples and oranges. Changing an 06+ header to the 03-05 header reduces back pressure and fueling much more than just a slip on. There are more variables in the equation than just the header. The 05 header is close to adding a full system to the 06+. Yes, a full system would flow even more, but the change in exhaust restriction is still significant.
Most of the backpressure in the R6S exhaust is created by the MUFFLER. When you put a slip on on a R6S, they don't run quite right without re-mapping. But the change in restriction isn't so drastic that you absolutely HAVE to add a PCIII.
Most of the back pressure in the 06+ exhaust is in the CAT. Putting on a slip-on, doesn't reduce the back pressure much, and not enought that the crude O2 sensor can't compensate. But replacing the header (along with the cat) does affect it quite a bit. And the stock narrow band O2 sensor (which the ECU still thinks is after cat) can't keep up. The R6S has no O2 sensor (which is another variable).
The two systems are very different. Just because they both say "R6" doesn't make them the same.
8Ball is offline
Rear set removal question r3x1mu5 General Discussions 1 07-13-2009 05:17 PM
Not a tire question but a wheel question rtitle Tire Tech Talk 2 07-06-2009 08:48 PM
emmissions control removal question da man Exhaust and fuel delivery 1 08-01-2008 06:00 AM
tire traction question Nate9982 General Discussions 10 10-21-2005 11:03 AM
520 conversion - DUMB QUESTION Tommy2003R6 General Discussions 3 07-08-2005 11:46 AM
