Question regarding cat removal. - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 40 (permalink) Old 02-02-2010, 07:23 PM
Re: Question regarding cat removal.
Originally Posted by 8Ball View Post
You are comparing apples and oranges. Changing an 06+ header to the 03-05 header reduces back pressure and fueling much more than just a slip on. There are more variables in the equation than just the header. The 05 header is close to adding a full system to the 06+. Yes, a full system would flow even more, but the change in exhaust restriction is still significant.
Most of the backpressure in the R6S exhaust is created by the MUFFLER. When you put a slip on on a R6S, they don't run quite right without re-mapping. But the change in restriction isn't so drastic that you absolutely HAVE to add a PCIII.
Most of the back pressure in the 06+ exhaust is in the CAT. Putting on a slip-on, doesn't reduce the back pressure much, and not enought that the crude O2 sensor can't compensate. But replacing the header (along with the cat) does affect it quite a bit. And the stock narrow band O2 sensor (which the ECU still thinks is after cat) can't keep up. The R6S has no O2 sensor (which is another variable).
The two systems are very different. Just because they both say "R6" doesn't make them the same.
for the 03-05 and 06+ r6s of course you need fuel mgnt for the simple reason of no o2 sensor. has anyone hooked a wideband to the mjs header to even see what the a/f was or is.
pm me
kaoss_11 is offline
post #32 of 40 (permalink) Old 02-02-2010, 07:25 PM
Just a dumb racer..
rich0's Avatar
Bike: Supersport R6
Kudos on totally ignoring the point.
rich0 is offline
post #33 of 40 (permalink) Old 02-02-2010, 07:30 PM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
The stock ECU doesn't know what to do with the feedback from a wideband O2 sensor. It reqiures a module like...oh I don't know...the Dynojet AutoTune to interface with it, but the AutoTune doesn't interface with the ECU directly. It communicates with a Powercommander. So your back to the remap. This setup just does it automaically.
8Ball is offline
post #34 of 40 (permalink) Old 02-02-2010, 07:34 PM
UR B-hind Da 8 Ball
8Ball's Avatar
When I referred to the 06+, I was NOT referring to the R6S. Iwas referring to the R6V, which is the bike that people do the '05 header mod to. There is little difference between the '03-'05 R6 and the '06-'09 R6S. (fuel management-wise)
8Ball is offline
post #35 of 40 (permalink) Old 02-02-2010, 07:54 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
No shit.. I'm done with this thread.
pickpocket293 is offline
post #36 of 40 (permalink) Old 02-02-2010, 08:13 PM
DynoMike
DynoMikeR's Avatar
Bike: 2006 R6 50th
Send a message via Yahoo to DynoMikeR
Hahahahaha. The big so called cat under these bikes is the MUFFLER! Like an automotive style, the slip on everybody refers too, is like an exhaust tip. The actual "cat" part is in the the two pipes in between the Muffler and the 4 main header pipes. Trust me, i have dissected my stock exhaust all apart to see what was going on. The cat is a honey comb, and it flows straight though. You can shine a flashlight in it and see right though it. But has a ton of surface area that stays crazy hot to burn any unburnt fuel that comes out of the combustion chamber, for emissions reasons. The big restriction is in the muffler, the big box under the bike. Take some time to cut shit apart and see whats going, so you better understand things. Im currently running an 05 header and Late model GYTR muffler. And yes it acts like a muffler. It has perforated core with packing. The stock slip on is straight though, basically no packing, and only a few perforations for tone, and the EX up valve. Like a valved exhaust tip. LOL! Yamaha has to meet strict epa standards for pollution and noise but still have good performance too. But we all like our bikes loud! Including me! Im sure ill hear all kinds of good comments back on this. HAhahahaha! Have fun with it.
DynoMikeR is offline
post #37 of 40 (permalink) Old 02-02-2010, 08:16 PM
Bike: 09 R6 Team fiat #46
Images: 15
i put a full Graves on my 09 and did not spend the money for the pc5 at first (Titanium header turned blue in less then 500 miles) so if u wont to get rid of the cat u will need a pc5 or your bike will run to lean its the best thing i've done to my bike so far
09r6barry is offline
post #38 of 40 (permalink) Old 02-04-2010, 05:23 PM Thread Starter
downsouthsoulja's Avatar
Bike: 09 R6
Alright. So my bike is done. Muffler was cutout completely, o2 sensor reinstalled, its been rainin all day so i wont be able to pick up the bike until tomorrow. I did however head down to the shop to check it out and was able to snap some shots and get a vid from my phone. Yes, i said phone so audio is not that great but you get the idea. Once I get her home tomorrow I will take better pics and get a better vid. she hasnt been dyno'd yet, but thats comin.
:F U
downsouthsoulja is offline
post #39 of 40 (permalink) Old 01-21-2017, 04:29 AM
just_banxx's Avatar
Still lost on what exhaust he has..years later
just_banxx is offline
post #40 of 40 (permalink) Old 01-21-2017, 06:16 AM
My 09 R6
fabianomc1's Avatar
Bike: 2009 YAMAHA R6
No, it won't hurt at all... i had the same thing done on my 2009 R6 and it runs perfect and actually I'm going to a track day even before the power commander. But its true that we gonna need to install the power commander on our bike!
FAB13
fabianomc1 is offline
Rear set removal question r3x1mu5 General Discussions 1 07-13-2009 04:17 PM
Not a tire question but a wheel question rtitle Tire Tech Talk 2 07-06-2009 07:48 PM
emmissions control removal question da man Exhaust and fuel delivery 1 08-01-2008 05:00 AM
tire traction question Nate9982 General Discussions 10 10-21-2005 10:03 AM
520 conversion - DUMB QUESTION Tommy2003R6 General Discussions 3 07-08-2005 10:46 AM
