Revving my engine then it dies?? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 7 (permalink) Old 02-24-2010, 02:24 AM Thread Starter
Ninja Rider
tolson's Avatar
Bike: 2006 R6 Raven
I installed a powercommander 3 awhile ago and uploaded a two brothers exhaust map on it...i hooked everything up and started my bike up..
First thing i noticed is that i had to give the bike extra gas in order to start up...((however not when the bike was all warmed up))
But then the worse part is when i revved my engine up high enough the rpms would drop back down so low that the engine shut off on me.... But then when the bike was really warm and i did the same the the bike would go down to low low rpms but just hang in there and not turn off..
I have a m4 slip on exhaust and there werent any maps for it...so i just uploaded that two brothers slip on exhaust map instead..
When i tried to upload any other maps i could not connect any more for some reason and i tired to restart and everything still no luck...
Does anyone know why my bike is doing this?? it never use to before..does this mean its a shitty map or what?
Any help would be greatly appreciated...(let me know if u need any more info on the situation)
tolson is offline
post #2 of 7 (permalink) Old 02-24-2010, 07:07 AM
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Re: Revving my engine then it dies??
The map isn't working for you. It probably needs more fuel in the lower RPM range at 0% throttle. If you are unfamiliar with changing maps, try another one. If you have a PC III, you can try adjusing the low range with the buttons, but that is not as precise, as it changes the map for the entire RPM range at all throttle positions.
8Ball is offline
post #3 of 7 (permalink) Old 02-24-2010, 07:18 AM
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
i was about to say the opposite. i think you're too fat at idle/low throttle. when i installed my bazzaz, the first few boxes changed from 0 to +15% (so it added 15% more fuel than stock). had this same problem until it got warmed up, and even then it still happened every now and then. after i leaned it WAY out at the bottom (back down to zero or -5%), she ran (and still does run) like a top. never had the problem again. good luck man.
Agg2001 is offline
post #4 of 7 (permalink) Old 02-24-2010, 07:38 AM
UR B-hind Da 8 Ball
8Ball's Avatar
That is entirely possible it could go either way. Most of the "downloaded maps" don't have any changes to the 0% column. It all depends on the difference between the bike/pipe combinations.
So to the OP, try going both ways and see what works.
8Ball is offline
post #5 of 7 (permalink) Old 02-24-2010, 09:42 AM Thread Starter
Ninja Rider
tolson's Avatar
Bike: 2006 R6 Raven
ok yeah well hopefully i can connect it to my laptop...ive been having so much trouble getting it connected...
I think what im going to do is to reinstall the pc3 application thing and download it again from their website.. hopefully something will work otherwise is there a way to replace the USB plug on them?
I think but not positive, that there were one or two little gold metal connectors on the pc3 plug that came out and now it cant make a good connection anymore :\
tolson is offline
post #6 of 7 (permalink) Old 03-01-2010, 11:46 AM
R6ShockSquad's Avatar
Bike: 2007 r6
I"m currently having the same problem, this is after I installed my yoshi r55 full exhaust. It idles rough, then when I give it some gas, it dies on me. I then installed the pc3 and downloaded the factory map for the exhaust, and still the same problem, did you have any luck figuring out the problem.
R6ShockSquad is offline
post #7 of 7 (permalink) Old 03-01-2010, 12:12 PM
Bike: 2007 r6
I got it to stop stalling at least by setting the all 0 throttle position to 0. Still have to fix the rough idle, Thanx for the tip guys
BMC vs K&N vs GYTR vs Pipercross Air Filter Rsexxyy Product Reviews 57 06-06-2014 09:52 AM
speedo dies then tach dies then engine! c0de 11 14 46 RRedR6 Garage / Mechanical Help 8 07-17-2008 06:42 PM
Engine problems, dies after hard use... fatts Garage / Mechanical Help 0 07-24-2006 04:20 PM
'06 Engine Dies? Race-R6 General Discussions 5 04-06-2006 01:24 PM
Help, shift and the engine dies? draconianruler Garage / Mechanical Help 4 04-16-2004 09:39 AM
