99-02 guys, post your carb settings/mods/elevation - Page 25 - Yamaha R6 Forum: YZF-R6 Forums
post #241 of 285 (permalink) Old 12-11-2012, 10:50 AM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
Re: 99-02 guys, post your carb settings/mods/elevation
Originally Posted by BBudensiek View Post
Ok so i have never messed with carbs... i work on fuel injected cars all day as im a auto tech. :P so i figured id give jetting my carbs a shot. I have no idea what my elevation is, havent searched it yet. i live in waterloo IA and i am looking to either just buy seperate jets or buy a factory pro kit. What do you guys recommend? And also if i dont get the kit do i just shim the needles? Any help would be appreciated!!! Thanks
Bryant
Yes, just shimming the needles will work (seems to work better then FP needles IMO). You could get close with the jets by studying some of the settings listed here, but may need to adjust up or down 1 size for your particular situation.
Originally Posted by o2r6rider View Post
Ok , since I have adjustable needles could I just copy your jet sizes and be better than the DJ setup? We have about the same engine mods. Or are the FP needles different than the DJ other than the notches?
If you do copy jet sizes, use genuine Kehin jets. Other than the notches, I really don't know about the DJ needles, I ended up putting the factory needles back in and shimming them before I got mine smoothed out (ended up adding another shim (think I'm at 1.1mm now) once I started hitting the track, made the 6-8k steady maintainer throttle around corners butter smooth, it was breaking up and annoying before).
CCS Racer #379
Bikez:
01' Champions Limited R6 (retiring from racing)
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (race project)
04' Zuma 50cc (have to get around in the pits)
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
99' CR125R (sold)
Shush319 is offline
post #242 of 285 (permalink) Old 12-11-2012, 12:38 PM
Go Fast or Go Home
Bike: 2000 Yamaha R6
ok so i figured out im 846 ft. above sea level so theres a start
2000 Yamaha R6 17,xxx miles. Carbon fiber pieces. DanMoto Carbon GT exhaust. 6k HIDS. Integrated tail.
BBudensiek is offline
post #243 of 285 (permalink) Old 12-11-2012, 01:32 PM
bgballin26's Avatar
Bike: 1999 R6
I would think my set up would be a close start for you, i'm at 875' above. My bike runs awesome other than at idle.
99 r6 ~ Factory Pro Jet kit with slight changes, OEM filter, TSR Frame Sliders, Dan-Moto Carbon Fiber GP exhaust, Renthal grips, JPR levers, pro tek bar ends, motion pro cables, Michelin Power 2ct tires, RK 520 conversion -1/stock rear, headlight signal conversion using 2003 r1 sockets, Luckybike.com flushmounts used as running lights, Puig double bubble windscreen
bgballin26 is offline
post #244 of 285 (permalink) Old 12-11-2012, 03:48 PM
Go Fast or Go Home
what are your exact specs...
post #245 of 285 (permalink) Old 12-11-2012, 04:58 PM
bgballin26's Avatar
Bike: 1999 R6
Check out the thread "idle got the best of me" i listed my set up there, also i just posted a video of my bike.
post #246 of 285 (permalink) Old 12-11-2012, 05:12 PM
Go Fast or Go Home
would these be ok to use for my needles?
http://www.powersportsuperstore.com/...tm?Click=35177
post #247 of 285 (permalink) Old 12-11-2012, 05:16 PM
Go Fast or Go Home
and also off this page here what all do i want to order?
http://www.jetsrus.com/a_jet_kit_str...600_YZF-R6.htm
post #248 of 285 (permalink) Old 12-12-2012, 09:23 AM
o2r6rider's Avatar
Bike: '02 R6
Those shims will be way too big.
o2r6rider is offline
post #249 of 285 (permalink) Old 12-12-2012, 02:48 PM
bgballin26's Avatar
Bike: 1999 R6
Is it possible to replace just the o-rings on the mixture screws? I can't find them without having to buy the whole screw kit.
post #250 of 285 (permalink) Old 12-12-2012, 04:07 PM
Go Fast or Go Home
where can i get some good shims?
quick question for you guys.... keepituponone General Discussions 10 07-23-2010 08:12 AM
Did Someone Post This Guys Cl Add On Here Before??? Ryan_06_r6_raven General Discussions 8 07-29-2009 02:07 PM
What do you guys think? -iceman- Exhaust and fuel delivery 30 09-03-2006 05:16 PM
hi guys can all 05 raven owner post your pics? saleman Appearance and Exterior Mods 9 05-06-2006 10:47 AM
