Idle Problem 04 r6 - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 13 (permalink) Old 04-15-2012, 12:51 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Re: Idle Problem 04 r6
Originally Posted by LudeNsoL View Post
so I changed out the plugs and it still has the same problem
How did the old ones look? Pics?
Did you get a power commander yet?
Can you check the resistance of your coils on a multi meter (check your service manual).
-Jamie M.
toysareforboys is offline
post #12 of 13 (permalink) Old 12-03-2012, 06:04 PM
Bike: '04 YZF-R6
Im having a weird problem with my 04 r6. When I first start up the bike it runs fine for like 30 minutes then it starts acting up. When I take off in first if I don't "ride" out the clutch then the bike stalls and wants to die. If I take off at like 3k rpms there are no problems and also full power through out the rpms.
New here and just picked up my new-to-me R6 tonight. I don't want to hijack this thread at all, but I just rode it home from the sellers house and experienced the same issue as above. At every stop sign, stop light, or starting in stopped traffic, I had to feather the clutch out to get the bike to take off cleanly. Could never cleanly release the clutch like I'm used to with my SV650, and I had to keep the revs above 4K to get off the line cleanly (read this was the case in a review from '04). I had the bike screaming to the clutch contact point to get it to roll. Stalled it twice. Bike has an aftermarket Akropovich exhaust and a Power Commander mapped to the bike-exhaust combo.
ttinker is offline
post #13 of 13 (permalink) Old 12-03-2012, 06:11 PM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
Sounds like both bikes need coils...
Modifications- PCV w/ Autotune, LCD, & Quick Shifter, GraveSport Slip-on, Slide Stops, K&N filter, Factory Pro +4 Ignition rotor, SuperFlare Velocity Stacks, AGG block off plates, Fren Tubo Type 4's, EBC HH Brake pads, 520 Driven Sprockets & EK ZZZ Chain, Penske 8987 shock, 07 USD Forks and Brakes in 05 Triples, ASV C5 Levers, Scotts Steering Damper, GYTR Carbon Chain Guard, GYTR Carbon Toe Guard, Canadian GYTR Frame Sliders, GYTR Carbon Tank Pad, BST Carbon Rear Fender, Competition Werks Fender Eliminator, UFO Integrated Tail Light, Metzler M5 D-Spec Tyres, Gilles Chain Adjusters & Lifters, Gilles Rear-sets, Powder Coated Passenger Rear-sets, GYTR Seat Cowl, SaddleMen Seat, Irate Customs Grill, Gregg's Flush Mount Signals, DDM 5K H.I.D.'s, Integrated Beltronics 985, and
Phrozen is offline
Idle Problem?? YamaR6Newbie General Discussions 1 03-01-2012 11:03 PM
Idle problem egonzo Garage / Mechanical Help 2 09-17-2011 08:02 AM
R6 flasher problem and idle problem mlewis Garage / Mechanical Help 0 04-29-2011 08:55 AM
Idle problem infiniti30 Garage / Mechanical Help 3 06-15-2008 01:19 AM
Low Idle Problem davek05R6 New Member Section 3 02-18-2006 03:17 PM
