Idle Problem 04 r6 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 13 (permalink) Old 03-13-2012, 05:34 PM Thread Starter
Bike: 2004 Yamaha r6
Idle Problem 04 r6
Im having a weird problem with my 04 r6. When I first start up the bike it runs fine for like 30 minutes then it starts acting up. When I take off in first if I don't "ride" out the clutch then the bike stalls and wants to die. If I take off at like 3k rpms there are no problems and also full power through out the rpms.
When the bike is idling the rpms jump like if I had cams but it always did this since I got it 4 years ago. it now has 20k
I called the dealer and there are no recalls.
Any suggestions?
LudeNsoL is offline
post #2 of 13 (permalink) Old 03-13-2012, 06:00 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Re: Idle Problem 04 r6
Any suggestions?
What exhaust is on the bike? Baffle in or out? Please list every single mod on the bike, no matter how insignificant. Clean/replace the air filter recently?
Does it have a power commander? Sure sounds like it needs one, especially with a loopy idle!!
-Jamie M.
toysareforboys is offline
post #3 of 13 (permalink) Old 03-13-2012, 07:27 PM Thread Starter
OK^ it has a D&D exhaust with baffle and I just changed the Air filter last month. No power commander and no other mods besides HIDS. I also have another D&D exhaust I use very rarely without baffle. Thanks
LudeNsoL is offline
post #4 of 13 (permalink) Old 03-13-2012, 07:35 PM
Bike: 07 R1
If the baffle is in I can't see it messing it up that much!
Download the service manual for your bike and look at the Diagnostics mode, specifically the TPS tests and readings. Check for any codes that are set as well.
A power commander would be nice, but can't guarantee it'll fix your issue.
-Jamie M.
post #5 of 13 (permalink) Old 03-13-2012, 07:45 PM Thread Starter
Thanks alot do you think chanhing the plugs would help?
LudeNsoL is offline
post #6 of 13 (permalink) Old 03-13-2012, 07:57 PM
Bike: 07 R1
If they are the original ones from 04, absolutely!
I recommend Denso Iridium 5367 (IU31A) spark plugs from Factory Pro (I know their website sucks donkey balls).
Way down at the bottom. Send them an e-mail to order because apparently spark plugs aren't compatible with their shopping cart
I also recommend the +4 ignition advance rotor while you're there
-Jamie M.
post #7 of 13 (permalink) Old 03-13-2012, 08:14 PM Thread Starter
thanks going to get them!
LudeNsoL is offline
post #8 of 13 (permalink) Old 03-13-2012, 08:22 PM
Bike: 07 R1
Nice! Make sure when uninstalling/installing the ignition advance rotor that the rotor/shaft does NOT move. Use an impact gun, or their screwdriver trick from their install video:
Also make sure the gasket they give you fits perfectly, I had to trim it slightly with an exacto knife (but they said that's cause mine was an R6S).
-Jamie M.
post #9 of 13 (permalink) Old 03-14-2012, 02:32 PM
Bike: 03 R6
Images: 2
there's a reason why the ignition cover has a screw that doesn't go to anything. it's so you can use a screwdriver to hold the rotor as you tighten the bolt to 25ft/lbs.
blue03r6 is offline
post #10 of 13 (permalink) Old 04-15-2012, 12:46 PM Thread Starter
so I changed out the plugs and it still has the same problem
LudeNsoL is offline
Idle Problem?? YamaR6Newbie General Discussions 1 03-01-2012 11:03 PM
Idle problem egonzo Garage / Mechanical Help 2 09-17-2011 08:02 AM
R6 flasher problem and idle problem mlewis Garage / Mechanical Help 0 04-29-2011 08:55 AM
Idle problem infiniti30 Garage / Mechanical Help 3 06-15-2008 01:19 AM
Low Idle Problem davek05R6 New Member Section 3 02-18-2006 03:17 PM
