2007 r6 APE Adjustable Cam Gears - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 2 (permalink) Old 04-09-2012, 10:02 AM Thread Starter
Mr. Speed
mrspeedsr6's Avatar
Bike: 07 yamaha r6
Send a message via Yahoo to mrspeedsr6
Has anyone ran these and if so how was they to get in time and also the specs, and has anyone ran the crower performance cams for the R6 and if so any specs on those for timing and how did they help out ?
mrspeedsr6 is offline
post #2 of 2 (permalink) Old 04-09-2012, 05:30 PM
"The Dude abides .. "
MELK-MAN's Avatar
Re: 2007 r6 APE Adjustable Cam Gears
having raced these machines quite competitively for 9 years, the stock camps are by far the most "rideable" and won't require kit springs or careful piston to valve clearancing. And before you get some adjustable cam gears, be sure what cam timing you want to run, then be prepared to spend some time on the dyno after that. Cam timing WILL GAIN YOU HP if the cam #'s are good numbers.. you can also mess your bike all up with "bad numbers". Builders won't just give those numbers out however as they make money doing it, and it likely took them days of dyno time to find good cam timing numbers that work.. and by work i mean work on track making good midrange and high end power, not just a big dip then spike to a high peak hp number..
If your just street riding, the R6 motor is VERY VERY strong and timed very well as is. There are ponies to be found with good dyno mapping without changing your cam timing numbers. And again, i do not suggest aftermarket cams unless your trying to do something very specific with the bike (like drag race - and why would you drag race an r6??)
OP: for your 07, you would be better off finding an 08+ adjustable v-stack assy, tank, ecu, harness, etc. and you will gain 10hp+- midrange and some up top, and it will cost less than a pair of aftermarket cams
MELK-MAN is offline
Gears JD62 General Discussions 1 04-25-2011 09:33 PM
Today I noticed I have six gears on my 2007 Yamaha R6 SNEL General Discussions 138 04-02-2010 12:15 AM
No gears other then First?? Slammedsi Garage / Mechanical Help 13 05-29-2009 07:25 PM
gears josh2007 General Discussions 0 09-10-2007 04:45 PM
2006 - 2007 R6 Adjustable Kickstand TAVAREZO Garage / Mechanical Help 0 11-07-2006 04:56 PM
