Flash Tune Interface - Review - FAQ - Page 126 - Yamaha R6 Forum: YZF-R6 Forums
post #1251 of 2696 (permalink) Old 12-04-2012, 03:00 PM
Bike: 07 Cbr 600RR & 06 R6
Re: Flash Tune Interface - Review - FAQ
FLASHED!
Thanks Jamie, I owe you one. We'll have some brewski's at the end of a TD this up comming summer
The reason for the lower rpm rev limit is so I don't get too carried away and blow the motor haha
going to the show this week? I'm only going to sign up for some TD's before they all disappear.
If you're not falling you're not trying hard enough
cbrkp is offline
post #1252 of 2696 (permalink) Old 12-04-2012, 03:08 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Originally Posted by cbrkp View Post
FLASHED!
Nice!!! When are you gonna try it out? It ain't snowin!
Sounds good. I'm going to try and run Calabogie a bunch next year, probably some TMP and Mosport too
I scored a free pair of tickets for the show so I'll for sure be going. My friend wants to buy a Ninja 300 but I heard they won't be at the show!!?
I have set the rev limiter to 16.5k for peeps and they ride the limiter all the way down the side straight at TMP and no problems yet, lol
TMP if you haven't been there:
-Jamie M.
toysareforboys is offline
post #1253 of 2696 (permalink) Old 12-04-2012, 03:18 PM
-Jamie M.
lol I would give it a try but I have no brake lever and no clip-ons haha... slowly putting it back together.
I checked the YCCT throttle table & for some odd reason the values are stock. I think it has to do with the software being buggy. so for the time being I don't think the throttle settings will work for me. I have emailed flash tune and I will call them daily till they pick up.
Interesting... the ninja 300? didnt even know they existed. I don't follow much of anything heh
being that its a track bike I don't want to kill it just yet, perhaps when I start racing then sure I'll rip that puppy right to red line if need be but its better to be safe then sorry in my books
TMP was actually the first track I ever rode, so I remember it pretty well
I may end up there but depends where I want to start racing either in SOAR or RACE.
cbrkp is offline
post #1254 of 2696 (permalink) Old 12-04-2012, 03:20 PM
btw when you adjust engine braking you do it with the fuel/ignition slider in general settings? You don't do it through the ignition map?
cbrkp is offline
post #1255 of 2696 (permalink) Old 12-04-2012, 03:31 PM
Bike: 07 R1
I don't think so! Stock, the bike snaps right from 60% throttle to 100% throttle at 8500RPM! In the map I made you it's a much smoother transition and brings you to the proper throttle openings at the right RPM for maximum power. The map is basically the same as stock except for at 65% throttle and over
Supposed to be a pretty sweet bike, slipper clutch, etc.
Would just murder the 600's and 1000's at TMP for sure!
Nice, TMP was my first track too! Good luck in your race events next year
Here's my 2nd track day ever! It's at TMP as well:
-Jamie M.
post #1256 of 2696 (permalink) Old 12-04-2012, 03:33 PM
Bike: 07 R1
In the new version of the software, 1.5.3.0, the fuel/ign slider bar works perfect for changing the maps! In every version prior it would totally mess up the maps and give you ZERO engine braking! SCARY!
So yep, I drag the slider bar, confirm timing and fuel additions/subtractions are correct for each gear, save the map, load it back up again, then double check the values again
-Jamie M.
post #1257 of 2696 (permalink) Old 12-04-2012, 03:40 PM
no no I'm sure you made adjustments to everything including the throttle table. The problem with my software is when I go to open up the throttle table all the values show like stock which leads me to believe the software is resetting the values. below is a screen shot of what I see when I open the throttle table. I've also tried to adjust the throttle table myself but it will automatically reset once I change to a different gear map or save and reopen
wow a slipper clutch haha thats crazy
cbrkp is offline
post #1258 of 2696 (permalink) Old 12-04-2012, 03:43 PM
Bike: 07 R1
Upload a pic of the general settings/main screen as well as the throttle table so we can see wtf is goin on!
-Jamie M.
post #1259 of 2696 (permalink) Old 12-04-2012, 03:48 PM
Bike: 07 R1
Map looks good, stock for comparison (look around 8500RPM):
-Jamie M.
post #1260 of 2696 (permalink) Old 12-04-2012, 03:51 PM
previous image above is the throttle table and this image below is the screenshot of general settings
cbrkp is offline
Anyone use ecu from flash-tune? ilian74 Exhaust and fuel delivery 119 03-31-2015 10:14 PM
micron slip on no tune vs. full ti leo with tune daisbest Exhaust and fuel delivery 2 09-06-2010 07:32 AM
Vega V-Tune Bluetooth Helmet Review Captscooter 954 R6 Product Reviews 3 08-25-2010 07:02 PM
Interface Talent Network dale bush Off Topic Talk 6 04-25-2010 03:09 PM
YEC Race ECU, Wire Harness, Cable Interface and software sonysnakeman Bike Parts For Sale 2 11-27-2008 06:24 AM
