Flash Tune Interface - Review - FAQ - Page 128 - Yamaha R6 Forum: YZF-R6 Forums
post #1271 of 2696 (permalink) Old 12-04-2012, 06:00 PM
mmerelles's Avatar
Re: Flash Tune Interface - Review - FAQ
Originally Posted by toysareforboys View Post
Yep! When I flashed two ECU's with the newer software (1.5.2.0) and it corrupted them both, I called them to rip them a new one! While I was on the phone with them I asked them about using my old 1.2.2.0 maps in the new 1.5.3.0 software, and that's when the said they just installed an in-house dyno and have been re-tuning all the stock yamaha maps. They had me open the 07 R1 map and sure enough it was totally different than the 1.2.2.0 one I'm running in my bike!
They even had people bring over their own bikes with different mods, etc. to work on maps for those!! They said they'll have some maps up on their website (map share) soon, that'll include FUEL tuning as well as ignition and throttle! There is one up already, for R1, apparently hauls some serious ass
-Jamie M.
thanks sir!!
I will have all day training on friday in preparation for sunday race, so i will try 1.5.3.0 and share you my impressions. It is a very known track for me, so it will be interesting to evaluate how this new maps perform on laptimes and handling compared to old ones having such a different tuning.
They should speed up autotune support on the ecu as well, it will rock!!!
mmerelles is offline
post #1272 of 2696 (permalink) Old 12-04-2012, 06:05 PM Thread Starter
OhioYJ's Avatar
I'm skeptical, they claimed to do dyno tunes before, were they renting one before or something? Not to mention they've claimed everything so far has made more power?
I've got to get some dyno time setup this spring and do some testing.
Either way I'm going to have to check out the new maps.
OhioYJ is offline
post #1273 of 2696 (permalink) Old 12-07-2012, 11:04 AM
Bike: 2011 Yamaha R6
Alright, map is complete!
Double checked throttle tables, everything is flawless
Dialed in approx 25% reduction in engine braking. If it's too much or not enough you can use the fuel/ignition slider on the main screen to adjust it. DO NOT TOUCH THE ETV SLIDER!
I've set up the map as if it was my bike. So Canadian (disable immob), disable O2 sensor (TPS vs RPM performance map only), 16.5k rev limiter (you can lower to 16k or 15k or whatever you want, don't go above 16.5k unless you have YEC valve springs), disable smog air pump (AIS), force idle to approx 1300rpm, quickshifter enabled (pin 21 on small ECU coupler), cooling fans 205/195, perfectly linear throttle table.
If you don't have a power commander or bazzaz already, I would load
into that map (import map button on main screen, then CLICK APPLY MAP, then flash).
Let me know how she goes
-Jamie M.
Can I use this for a 2011 r6? and if so what do i change to make engine braking as close to stock as possible?
Njbr6 is offline
post #1274 of 2696 (permalink) Old 12-07-2012, 06:11 PM
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
Ummm, no. The map wouldn't be called 06-07 R6 if it worked on 2011's too
lol.
Just use the built in 2008-2011 R6 91+ map. Don't touch the engine braking sliders and it'll be as close to stock engine braking as possible (should be really close).
Dump in OhioYJ's
if you've ditched the cat and flash away!
-Jamie M.
toysareforboys is offline
post #1275 of 2696 (permalink) Old 12-08-2012, 06:56 PM
mmerelles's Avatar
I rode the first three sessions on the old version/maps having lapped 1:58:500 consistently, then i flashed the bike with 1.5.3.0 and included maps.
First I noticed, the bike has now a solid rock idle at 1500 cold and hot (it used to bounce a lot while idling cold and hot).
At the track the bike now pulls consistently through the entire RPM range, not flat spots, neither peaks. The throttle is soooo smooth now (used to be very peaky and unpredictable) that you end up opening it sooner and sooner at very high lean angles with high grade confidence and precision.
This new version is definitively a major step forward on handling at the track (I have no dyno to confirm hp numbers). Anyway, it so smooth and predictable now that you can open it sooner and stronger at the tire edges while exiting a corner lapping faster. I put a 1:57:478 (a second faster) on qualifying which gave me to the pole for tomorrow.
Engine braking was improved as well, on the older version it was a bit inconsistent while coming in hard to the turns. It is more linear and consistent now.
Mine is a R6 2011 EURO SPEC. Hope to see other reviews of the new version
post #1276 of 2696 (permalink) Old 12-09-2012, 04:11 PM
Bike: 07 R1
Woot woot! Nice! I would e-mail your results to Flash-Tune. They'd probably sponsor you with a review like that
I've flashed three bikes with the 1.5.3.0 now, all of them said it feels way way better. Peak HP number might be the same or less, but damn it's so smooth and not twitchy!
-Jamie M.
post #1277 of 2696 (permalink) Old 12-09-2012, 04:44 PM
Tropicoz's Avatar
Jamie, in using the latest software, have you been using their throttle maps? I've built a few to narrow down next spring, but with every update there is less and less difference between my stuff and theirs!!!
Tropicoz is offline
post #1278 of 2696 (permalink) Old 12-15-2012, 05:55 PM
Will the new 1.5.3.0 Software and maps decrease the throttle sensitivity using FlashTunes throttle map? Right Now,running 1.2.2.0, its hard for the bike to hold and steady rpm and makes it difficult in the corners because the bike accelerates too much. Just looking for some feedback and maybe reflash my ECU with the new software.
bmxrider945 is offline
post #1279 of 2696 (permalink) Old 12-17-2012, 06:09 PM Thread Starter
OhioYJ's Avatar
To everyone that has PM'd me, between moving this week and a family issue that came up, I haven't replied to any PMs. I will answer everyone, just bear with me as there will be a delay.
It's actually just the mapping, not the version number really. The original maps for the flash tune software were kind of twitchy, and the reason I stopped using their maps. The new throttle map, is much smoother, however, not quite as aggressive. I still prefer a slightly more aggressive map, but it's a personal preference (It took me a while to get a custom setup how I like). If you were having problems with a twitchy throttle the newer maps will definitely help, just be aware, it's a little less aggressive.
- Offline license checking bug fixed allows for faster loading
- Linkmaps disallowed with YCCT mapping
- Flash routine updated to support bluetooth interfaces
- PC value grid auto clears when applying to "current image"
New update, wonder what the bluetooth part is?
OhioYJ is offline
post #1280 of 2696 (permalink) Old 12-20-2012, 05:39 PM Thread Starter
OhioYJ's Avatar
Well I'm moved, and things are getting back to normal again. Everyone should have PMs now if I have your ECM, telling you wether it shipped today, or will be tomorrow.
I will say the latest version is much better than the last few versions. I'm actually finally running the newest software on my ECU, and am happy with the results.
OhioYJ is offline
Anyone use ecu from flash-tune? ilian74 Exhaust and fuel delivery 119 03-31-2015 10:14 PM
micron slip on no tune vs. full ti leo with tune daisbest Exhaust and fuel delivery 2 09-06-2010 07:32 AM
Vega V-Tune Bluetooth Helmet Review Captscooter 954 R6 Product Reviews 3 08-25-2010 07:02 PM
YEC Race ECU, Wire Harness, Cable Interface and software sonysnakeman Bike Parts For Sale 2 11-27-2008 06:24 AM
