Bike won't start...another one. - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 43 (permalink) Old 11-01-2012, 04:44 PM Thread Starter
My R6 is trouble.
topherchris's Avatar
Bike: 2007 R6 - 2006 R1
Update: been working on my dirt bike since I know what's wrong with that. I pulled the fuel rail and injectors and all looks well. The gas did this funny bubble thin with I spilled it out of the fuel rail onto the ground, it looked like it was boiling but no bubbles...I've never seen this but I've also never dumped any amount of gas onto the ground. Bad gas maybe? I'm going to drain the tank tomorrow and refill to check. If its not that then it's got to be electrical (I think) because the fuel pump is outputting fuel (there was pressure in the line when I disconnected it) and it runs on starter fluid.
topherchris is offline
post #32 of 43 (permalink) Old 11-01-2012, 05:07 PM
motoman21's Avatar
Bike: '12 R6
Re: Bike won't start...another one.
Very interesting. I hope you get this resolved, good luck.
motoman21 is offline
post #33 of 43 (permalink) Old 11-13-2012, 01:22 PM Thread Starter
My R6 is trouble.
Went out and drained all the gas...it looked oily a little so I think bad gas maybe. I also picked up noid lights on the way home from the local parts store. I used the one that best fit the plug and tried it both ways with no light at all. I plugged it into the harness and attempted to crank it over. Only tried one plug (the left one) before I posted this because I'm not sure if I'm doing it right. Any inputs? I'm about to go get good fuel and plug everything back up and hope that it solves the problem. I've already drained both sets of injectors, connections, fuel rails, and tank.
Sent from my iPhone using
post #34 of 43 (permalink) Old 11-14-2012, 03:00 PM Thread Starter
My R6 is trouble.
Huge update...cylinders one and two aren't getting a pulse...3 and 4 are though. Any ideas?
post #35 of 43 (permalink) Old 11-15-2012, 01:55 PM Thread Starter
My R6 is trouble.
Bought a main harness and injector harness and plugged them up. Now none of the cylinders are getting a pulse. Stand by for a part out thread.
post #36 of 43 (permalink) Old 11-15-2012, 03:22 PM
"The Dude abides .. "
MELK-MAN's Avatar
how long did this bike sit .. you discussed "bad gas" many times. Stuck fuel injectors will not improve with new gas, or any amount of seafoam or other gas treatments. If they are stuck, they are stuck, and can only be served off the machine. You do NOT need new injectors (that is what we do).
I was a bit confused by the post regarding pulse to the injectors. were you testing with a meter to determine if the injector harness was sending a signal to the injectors? or are you simply assuming since the injectors are not pulsing, it's a wiring/harness issue?
Have you tried another ecu?
MELK-MAN is offline
post #37 of 43 (permalink) Old 11-15-2012, 03:33 PM Thread Starter
My R6 is trouble.
No, I concluded they weren't firing using niode lights (it's a light on a plug that plugs into the harness where the injector plugs in). I'm down to the ECU, I haven't tried a new one yet, that is my next shot at it and what I now believe to be the problem.
post #38 of 43 (permalink) Old 11-15-2012, 04:05 PM Thread Starter
My R6 is trouble.
And to answer the sit time question...it worked one day, then the next day following full up it didn't run. Another twist...I went in with a voltage light (the kind used to find grounds) and the light lot for every cylinder. I'm going to take the injectors to Lee's in the morning. When attempting to start it, it deff wants to start, it's almost there but won't quite start. It'll "run" as long as I'm cranking it but as soon as I let go it dies out.
post #39 of 43 (permalink) Old 11-15-2012, 04:28 PM Thread Starter
My R6 is trouble.
I just got it to idle until I touch the throttle then it dies
post #40 of 43 (permalink) Old 11-15-2012, 04:33 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Still?!
pickpocket293 is offline
Help, bike won't start xracer Garage / Mechanical Help 6 05-20-2012 01:32 PM
Bike won't start, or will barely start but dies tkc Garage / Mechanical Help 13 10-12-2011 01:35 PM
Bike will not start Riztnack Garage / Mechanical Help 5 04-02-2010 01:53 PM
Bike Won't Start jmk1223 Garage / Mechanical Help 10 03-27-2010 10:11 AM
Help new bike won't start R6_AT_Kobra General Discussions 10 03-05-2006 06:21 AM
