11' gtyr slip on. - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 8 (permalink) Old 11-17-2012, 04:14 PM Thread Starter
But I ride a Yamaha!
honda4life05's Avatar
Bike: 11' Red Raven
11' gtyr slip on.
Hey guys i'm just looking to clear up on some information that I have been reading. I'm looking to get rid of the long ugly silver stock exhuast and put on a carbon gtyr slip on, mostly for astetic reasons, and if is a tad louder I wouldn't mind. Is that what the slip on mostly does? Also i read that If i take off the werx cables going to the pipe BUT still leave the motor plugged in, i do not need the little modual to fix the error light coming on? That little piece is $60! thanks for any help!!
honda4life05 is offline
post #2 of 8 (permalink) Old 11-17-2012, 04:18 PM
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
Correct, slip on are mostly for looks and sound, not performance. You can leave the EXUP cables hanging and you will not receive a CEL. I believe there's a $3 mod on here to make you own EXUP eliminator plug Instead of paying $60. Removing the servo motor cleans up the under tail area a bit as well and you lose about 1-1.5lb of weight.
Sent from my iPhone using
bluerebel is offline
post #3 of 8 (permalink) Old 11-17-2012, 06:07 PM Thread Starter
Bike: 11' Red Raven
Re: 11' gtyr slip on.
Is it possible to removie the cables from the motor so that their not hanging there? I thought I saw a how-to but can't find it! Also should the bike still run like I have a stock exhuast? no idle problems? I assume is should especially since it's a yamaha accesory
post #4 of 8 (permalink) Old 11-17-2012, 06:22 PM
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
I guess you can cut them... My opinion is.... If your going to do a mod.... Don't have ass it and do it right the first time bro.
Also, there should be no idle issues. Again, slip ons are mainly for sound/ looks
post #5 of 8 (permalink) Old 11-17-2012, 06:25 PM
QR6
PHX-602
QR6's Avatar
Bike: 2007 R6
Images: 6
Yes you can remove the cables and leave the servo motor connected.
Go to youtube to find how-to's. That's what I did until I got my ECU flashed by BAUCE Racing, then I removed the servo motor too.
Quintin - 2007 Street to Track & Back R6
ASMA #26 early retirement
My build thread:
QR6 is offline
post #6 of 8 (permalink) Old 11-17-2012, 06:30 PM Thread Starter
Bike: 11' Red Raven
Thanks I knew I saw it somewhere!
post #7 of 8 (permalink) Old 11-28-2012, 12:27 AM
Bike: 2012 r6
Images: 1
i just put my carbon GYTR slip on, on my 12' r6 just yesterday. Removing the exup cables and putting my slip on took about 20 mins. under the tall in fdront of the shock youll see i rubber case with two bolts unscrew that and the servo will come out and open the rubber case and disconnect the cables but leave the servo plugged in...you will loose a little power in the lower RPM range cause removing the cables will make the servo think the butterfly stays open all the time, cause no back pressure.
JAYS12R6 is offline
post #8 of 8 (permalink) Old 11-28-2012, 09:00 AM Thread Starter
Bike: 11' Red Raven
I have heard you lose low end power before, can you notice it alot? these machines dont have much on the bottom even with the stock can so I may just leave it alone
If you ain't first, you're last.
Yoshi header/mid to GTYR slip on. Its being a PITA. marioaldayuz Exhaust and fuel delivery 1 09-28-2010 09:03 AM
GTYR slip on. catawissar6rocket Bike Parts For Sale 0 02-08-2009 01:17 PM
GTYR slipon w/ GTYR Airfilter PCIII Map????? BullydogR6 Exhaust and fuel delivery 2 05-11-2008 08:46 PM
Got gtyr on. R6Parks Exhaust and fuel delivery 1 03-29-2008 04:44 PM
F/S GTYR Slip-on Baysideblues Bike Parts For Sale 18 12-31-2007 08:18 AM
