07 R6 Rough Idle - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 15 (permalink) Old 12-06-2012, 11:14 AM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
07 R6 Rough Idle
Here is a link for the video.
Any ideas or suggestions why it's dipping from 1,400rpm - 1,050rpm? I read a few posts that suggest it could be back presser, battery, coils or throttle bodies. I just did a full tune up 600 miles ago changed the plugs, flushed the coolant, changed the brake fluid, checked the air filter, changed the oil and oil filter.
Ty
1992 Kawasaki Ninja 250 - Sold
1997 Honda CBR 600 F3 - Sold
2006 Honda CBR 600 F4i - Sold
2007 Yamaha YZF-R6 - Sold
WiSH2oo0 is offline
post #2 of 15 (permalink) Old 12-06-2012, 11:16 AM
Suk it, Lee
Ryan5544's Avatar
Re: 07 R6 Rough Idle
What air/exhaust/engine mods you have?
Ryan5544 is offline
post #3 of 15 (permalink) Old 12-06-2012, 11:25 AM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
Opps, forgot to list those.
Driven Smog Block Off Plates
PC-V(MJS 250 RPM Map)
AutoTune
DIY Exup Removal Mod
M4 Y-Pipe(Welded and Cats Still Intact)
HB MGP Growler Slip-On
Stock Air Filter
WiSH2oo0 is offline
post #4 of 15 (permalink) Old 12-06-2012, 11:37 AM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
I've also tried to change the fuel map on the PC-V in Throttle 0% from 500rpm - 2,250rpm to Zero, 2, 4, 6 all the way up to 20 w/ no change in the idle. I'm currently running Throttle 0% from 500rpm - 2,250rpm at 12.
WiSH2oo0 is offline
post #5 of 15 (permalink) Old 12-09-2012, 04:59 PM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
Battery checked out fine
Coil Ohms Left --> Right
1.5Ω / 8.98kΩ
1.5Ω / 8.84kΩ
1.5Ω / 8.97kΩ
1.4Ω / 8.84kΩ
Whats next?
WiSH2oo0 is offline
post #6 of 15 (permalink) Old 12-09-2012, 10:36 PM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
Well I put everything back together again and still idles like in the video. I guess next step is to unplug the PC-V and Autotune for poops and giggles. I've been searching the web for the last hour and seen many people have this problem
I just find it hard to believe that no one has found a fix since this bike has been out since 2006.
WiSH2oo0 is offline
post #7 of 15 (permalink) Old 12-09-2012, 11:38 PM
Bike: 05 R6
have you checked the spark plug coils?
cornerjunkie is offline
post #8 of 15 (permalink) Old 12-12-2012, 05:46 PM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
I figured it out finally! I read a post Jamie M(pic posted by Jamie M.) made here about the EXUP and back pressure found here
So I went out into my garage and fired up my bike. I then put my hand over half of the exhaust pipe to simulate having the EXUP valve and Walla
The bike was idling smooth as silk at 1,300 rpm. So my next question is, will this cause any problems with my bike in the future?
WiSH2oo0 is offline
post #9 of 15 (permalink) Old 12-12-2012, 06:20 PM
the idle from LO to 104 is going to be rough no matter what, nothing you do will change that.
I saw no problems with your idle in that video. seemed perfectly normal to me with the current mods posted.
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline
post #10 of 15 (permalink) Old 12-12-2012, 06:52 PM Thread Starter
WiSH2oo0's Avatar
Bike: 07 R6
Indeed, my Honda F4i did that also while it was warming up. But once my Honda got off fast idle it was rock sold at 1,300 rpm. My Yamaha after it's up to 170F the idle was still dropping from 1,450 - 1,025 rpm. I've never seen anything like this before. It must be a Yamaha thing cause my Kawasaki and Honda's did not do that after I made exhaust and fuel mods.
If you fast forward to the last minite you will see the bike is at operating temp and still idling like garbage.
I think you people do not even read the posts just the heading cuase the 1st guy asked for my mods when they are listed in my sig. The second guy said to check my coils when I already listed the ohms readings for each coil. You probley only watched the 1st 30secs of my video and jumped to a conculion that it was running fine.
Thx for trying though
WiSH2oo0 is offline
Rough Idle and Take Off CS-Reaver Garage / Mechanical Help 1 08-04-2016 11:51 PM
08 r6s rough idle and take off CS-Reaver Garage / Mechanical Help 1 07-29-2012 10:03 PM
Rough Idle Local_r6 Exhaust and fuel delivery 4 06-23-2011 10:53 AM
help...Rough Idle big_vincent General Discussions 0 03-20-2005 05:22 PM
rough idle?? chukiechz General Discussions 8 08-29-2003 01:50 AM
