Idle got the best of me! - Page 3 - Yamaha R6 Forum: YZF-R6 Forums
post #21 of 75 (permalink) Old 12-12-2012, 11:42 AM
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
Re: Idle got the best of me!
It means 1&2 are rich, or they are out of sync. When was the last time they were sync'ed?
CCS FL #379
Bikez:
01' Champions Limited R6 (retiring from racing) now traded for a truck :-( gonna miss the old girl))
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (Race/Street)
04' Zuma BEAST MODE ENGAGED! 70cc S6 BBK and pipe, 68mph on flat land!
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
90's Blata 40cc water cooled pocket bike (seriously dangerous! 50mph with my 170lb azz.)
99' CR125R (sold)
Shush319 is offline
post #22 of 75 (permalink) Old 12-12-2012, 12:04 PM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
I synced them a couple of months ago but i had trouble with the gauges (old home made set up). They are a pain to get to the vacuum ports to sync them! But i guess i will order a motion pro sync tool and try that, should i bother pulling the carbs apart or should i sync them 1st and see how it reacts?
99 r6 ~ Factory Pro Jet kit with slight changes, OEM filter, TSR Frame Sliders, Dan-Moto Carbon Fiber GP exhaust, Renthal grips, JPR levers, pro tek bar ends, motion pro cables, Michelin Power 2ct tires, RK 520 conversion -1/stock rear, headlight signal conversion using 2003 r1 sockets, Luckybike.com flushmounts used as running lights, Puig double bubble windscreen
bgballin26 is offline
post #23 of 75 (permalink) Old 12-13-2012, 11:35 AM
Shush319's Avatar
Bike: listed in sig
Definitely sync with a real sync tool, makes a big difference.
CCS FL #379
Bikez:
02' R1 (sold)
01' XR70R (sold)
99' CR125R (sold)
Shush319 is offline
post #24 of 75 (permalink) Old 12-13-2012, 02:03 PM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
I picked up a Motion Pro sync tool, a guy i ride with had it, he used it once and sucked all the fluid out, so i have to order the fluid, he said he didn't calibrate it. I took my carbs apart and cleaned them real good, inspected everything, put them back together, i turned the screws to 2 turns just to see what happens, and now it hangs around 2500 rpm for a split second, it will not run at all with the choke on which is bizarre. I think i will go back to 2.5 turns and hope the sync will smooth it out.
post #25 of 75 (permalink) Old 12-13-2012, 04:27 PM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
Pulled the carbs back off, set them at 2.5 turns out, noticed the boots on the airbox were pulled halfway out, so i pulled the plate off, put them back in place and put it all back together, it's back to normal now, except the idle isn't bouncing around that bad, i can actually idle it at 1500 rpms instead of 1800 rpms, now the waiting game for the fluid so i can refill this sync tool. I'm ready for a F.I. bike..
post #26 of 75 (permalink) Old 12-14-2012, 07:16 AM
Shush319's Avatar
Bike: listed in sig
Should idle around 1250-1350 when its all good, this is where it needs to idle when syncing too. These things always bounce a little at idle, but yours sounded abnormal. When you get it sync'ed right, you'll probably be much happier. I check the sync on mine every 3 months just because I'm that anal about my bike. I remember reading in a manual somewhere that it should be done every 4000 miles.
CCS FL #379
Bikez:
02' R1 (sold)
01' XR70R (sold)
99' CR125R (sold)
Shush319 is offline
post #27 of 75 (permalink) Old 12-14-2012, 08:26 AM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
Does it take a special tool to get in between the carbs to adjust the screw? I tried my skinniest screw driver and it didn't fit?
post #28 of 75 (permalink) Old 12-15-2012, 08:24 AM
Shush319's Avatar
Bike: listed in sig
Its a pain in the azz, but a skinny phillips is what you need. You just have to find the right place to get at it from.
CCS FL #379
Bikez:
02' R1 (sold)
01' XR70R (sold)
99' CR125R (sold)
Shush319 is offline
post #29 of 75 (permalink) Old 12-16-2012, 06:28 AM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
Does it matter which carb i use to calibrate my motion pro sync tool?
post #30 of 75 (permalink) Old 12-18-2012, 04:47 PM Thread Starter
bgballin26's Avatar
Bike: 1999 R6
I got my carbs synced today, had several problems with my Motion pro sync tool, i'm not too crazy about it, 2 of the 4 restrictor jets were clogged, anyways it was way out of sync, it took me awhile of adjusting, adusting the idle, i finally got it synced about as perfect as you can get with that tool. Bike runs so much smoother, idles smooth, only one problem, it's idling around 1600 rpms and my idle adjustment is turned out all the way. So what does this mean?
low idle sergefer New Member Section 0 07-19-2012 06:15 PM
HELP, Stalling at idle (wont idle) bodhi Exhaust and fuel delivery 10 06-15-2012 12:14 PM
R6 Bad idle s.humberstone90 General Discussions 0 01-29-2012 10:09 AM
04 idle screw doesn't change the idle geeniusatwurk Garage / Mechanical Help 4 01-15-2010 10:05 AM
Idle RPM ?? J.DenhamR6 Exhaust and fuel delivery 2 05-04-2008 11:30 AM
