Cat Delete Issues. - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 16 (permalink) Old 11-01-2016, 12:53 PM
~C@TcH mE iF U c@N~
tones160's Avatar
Bike: 05 R6 - Cherry
Re: Cat Delete Issues.
+1 to the slip on and flash
tones160 is offline
post #12 of 16 (permalink) Old 11-01-2016, 01:44 PM
doidera00's Avatar
Post is 2 years old
Sent from
doidera00 is offline
post #13 of 16 (permalink) Old 11-01-2016, 10:15 PM
\_(ツ)_/
modrid81's Avatar
Bike: '09 R6R Raven
Originally Posted by gaytan1978r6 View Post
Haaa ok.. i have the stand alone bazzaz quick shifter if i add the bazzaz zfi will it do the trick..
TBH, unless you're going to be swapping out parts and tweaking A/F ratio settings and stuff, an ECU flash is about half the cost. I knew that I wasn't going to swapping out anything on my bike after settling on the exhaust setup I liked, so I went with the flash. Just wasn't worth the extra money to be able to change something, b/c my bike is essentially set. Now, if you're going to track it, yeah you will want the full options. For daily riding, a flash does everything else. ChiefSmokeDawg will have you fill out some info on what you're looking to do, and will tailor the flash to your needs. He knows his shit, for sure.
Originally Posted by doidera00 View Post
Post is 2 years old
Eh, he gets points for actually searching...
2009 Yamaha R6 Raven, BAUCE ECU flash, K&N filter, Agg Racing block-offs, M4 mid-pipe w/Yoshi Ti TRC can, Galfer lines, EBC HH front pads, Zero Gravity DB, DDM HIDs, Hotbodies smoked flushmounts, Lockhart Phillips smoked integrated tail, TST Industries Elite-1 fender kit
modrid81 is offline
post #14 of 16 (permalink) Old 11-01-2016, 10:16 PM
Thanks.. for the tips
gaytan1978r6 is offline
post #15 of 16 (permalink) Old 11-02-2016, 08:24 AM
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
With the ECU flash I can map the ECU for the mid pipe and slip on setup. But there's also many many other things we do in the flash. Right now you're only seeing 100% throttle for about 2000 RPM's in the RPM range. The engine braking is reduced, the idle raised, the on/off throttle will no longer be like a light switch (either on or off).
Send in the form on the site and we can make it happen and I'll answer all your questions.
ChiefSmokeDawg is offline
post #16 of 16 (permalink) Old 01-21-2017, 04:16 AM
just_banxx's Avatar
Pcv+flash
just_banxx is offline
Cat Delete? Pips722 Exhaust and fuel delivery 8 01-28-2017 10:05 AM
cat delete nyc2k11r6 Exhaust and fuel delivery 8 07-09-2013 08:27 PM
Y-pipe/Cat Delete help! jrobMSU Exhaust and fuel delivery 20 03-24-2013 01:59 PM
2008 cat delete miketilney Exhaust and fuel delivery 13 08-18-2011 07:51 AM
M4 cat delete?? Zr2mudder00 Exhaust and fuel delivery 18 12-27-2010 07:50 PM
