Auto Tune problems - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 02-11-2017, 05:32 AM Thread Starter
Auto Tune problems
Before I email Power Commander i wanted to make a post here, because I'm afraid PC will tell me I have a defective Auto Tune, which would suck considering its already spliced in and installed. I have a 2008 R6 with a Graves full exhaust system and I'm running the Graves PC map. I installed an Auto Tune because my bike was running too rich. At first, everything is fine. The bike runs much better with the AT, and after getting my first trim it basically leans my A/F ratio out across the board, which is exactly what I needed. I'll apply my trim, and head out for another ride. At first everything is fine, the bike runs great. But all of a sudden I'll start having problems. The throttle response becomes choppy and horrible. Ill try to cruise at a low rpm with the throttle cracked open and my bike will start 'jumping' or cutting in and out sorta, like its trying to stall. My bike will not want to accelerate, Ill have to really twist the throttle to get it to go. Getting on and off the throttle is super choppy as well. There seems to be correlation between these problems and turning my bike on and off a few times. Like I said, at first things are fine. But lets say its like my 3rd time starting my bike since applying the trims - I decide to stop for gas or something. When I turn my bike back on, out of nowhere the problems begin. I've tried restarting by loading the original Graves map onto my PC again and that does work, but it will end in the same result. Any help is appreciated!
yzfBrandon is offline
post #2 of 12 (permalink) Old 02-12-2017, 06:42 AM
OhioYJ's Avatar
Re: Auto Tune problems
Wait how many times are you applying trims?
I have a section on the AutoTune in my FAQ at the top, it's not long, but I would give it a quick once over (it won't take long).
OhioYJ is offline
post #3 of 12 (permalink) Old 02-12-2017, 07:30 AM
Just lean harder...
Phrozen's Avatar
Bike: 07 R6s
Read through the above posted link and let me add that it is a good idea to put a switch on the autotuner so you can turn it on and off. The auto tune does not like choppy throttle inputs like ripping up corners going on and off the throttle fast. It likes smooth throttle input to actually auto tune. Do not have an AFR value in the 0% throttle column anywhere. I also simplified the AFR map to basically 13.2 across the board and 13.0 in the higher RPM's. Hope this helps.
Phrozen is offline
post #4 of 12 (permalink) Old 02-12-2017, 03:17 PM
OhioYJ's Avatar
It still shouldn't behave like hes describing. My autotune has been on and active since installed years ago, and working perfectly. One of the advantages to DynoJets AutoTune is its live changes in my opinion. My map also has AFR targets that change throughout the RPM band and in the 0% throttle.
OhioYJ is offline
post #5 of 12 (permalink) Old 02-12-2017, 03:19 PM
OhioYJ's Avatar
OP can you post your map?
Does the bike sound noticeable different like its missing when this happens?
OhioYJ is offline
post #6 of 12 (permalink) Old 02-13-2017, 12:11 PM Thread Starter
I'll apply my trims 1 time, and it will happen on the subsequent ride. It will be fine at first, but after i turn the bike off and on about 3 times it will all the sudden begin having the problems I described. Maybe It's just coincidence, but both times it happened immediately after turning my bike on after stopping somewhere, and persisted until I got back home.
I believe I reloaded the original map last time I had my bike out, but we are getting some nice weather at the end of the week and ill try to get out then and get a trim for you. Also, there doesnt seem to be any noticeable difference in sound
post #7 of 12 (permalink) Old 02-13-2017, 12:31 PM Thread Starter
AFR values is actually one the culprits I think could be possibly responsible. I cant remember if I have AFR in the 0% column, but i know i have an AFR value in basically every cell, including rpm's at idle and even below idle. It was that way by default. I watched a video by dynojet and they suggested not having AFR set at all at 2% throttle, and not until around 6k rpm's at 5% throttle. Do you think that could have something to do with it?
post #8 of 12 (permalink) Old 02-13-2017, 02:52 PM
nova r6
tdoss1980's Avatar
Bike: 05 r6 Camo/Orange
Random thought, what if the 02 sensor was going bad? Because if the O2 is giving false readings and your accepting the trims that could throw your maps way off.
Do you have a shop close to you with a dyno and able to read a/f ratios? If they do you can compare what your a/f reading on the pcV software to theirs and see if they are the same.
March 2014 Bike of the month
tdoss1980 is offline
post #9 of 12 (permalink) Old 02-13-2017, 05:31 PM
OhioYJ's Avatar
I once had an issue that turned out to be firmware related with the PCV, but it was turning off the injectors. The bike would run horribly though obviously. It was only turning off two of the four that it controls.
OhioYJ is offline
post #10 of 12 (permalink) Old 02-24-2017, 01:31 AM Thread Starter
Okay here is a picture of my trims after a few days of riding. I've come to realize that if I don't accept and apply my trims, I won't have any issues. It still wants to be a little sluggish when I crack the throttle at about 2 and 5%, but nothing like the problems I mentioned in the original post. The enrichment/enleanment parameters were left at 20. Also included a pic of my A/F. Hopefully you can read the pictures, I first tried using the snippit tool in windows but that made the file size too big.
ID:	327746   Click image for larger version
ID:	327754   Click image for larger version
ID:	327762   Click image for larger version
ID:	327770   Click image for larger version
PC V and Auto Tune help MinnesotaTA Exhaust and fuel delivery 119 08-22-2011 12:17 PM
auto tune help Hyphy General Discussions 4 07-19-2010 02:05 PM
Auto tune Rushe06 General Discussions 2 04-21-2010 08:58 PM
auto tune fishman Exhaust and fuel delivery 2 11-07-2009 10:35 AM
Auto tune for Custom Tune for PcV Toafster Exhaust and fuel delivery 1 03-11-2009 04:39 PM
