so just dropped new plugs, removed AIS and installed agg block offs and added the bmc race filter (no restrictor) and now it is really loud right under the tank, sounding like a mid to higher pitch engine noise but loud. if air filter is not completely sealed around air box would this be a symptom? i did not reinstall that plastic cover with that attaches to the AIS since its no longer there and can't clip into anything...any ideas?
After installing the smog plates, I noticed mine made a new noise up front. I just figured that was normal, if its the same noise you are talking about.
hi ohioyj, guess i didn't install the block off plates correctly. when i removed the AIS i took out the pump with hoses attached and then unbolted those plates but thats it. what else do i have to remove? that copper color thing?
Did you install the block offs correctly? When i did mine, i installed the block offs in the wrong direction resulting in basically a small exhaust leak. It was obvious as soon as i started the bike up, loud clacking noise. Also, i have the same air filter with no restrictor and it does make a slightly different noise.
Don't forget to get your Toce Double Down exhaust before you flash. Last time I got pulled over cop said he was listening to me drive around town for about 30 mins before I passed him. Obnoxiously loud and sick looking! Click my profile pic.
toce :laugh if you're going that route just buy yourself a chrome tip at the autoparts store and save yourself money.
Related Threads
3.1M posts
112.1K members
Since 2003
