All your Bazzaz Questions - Page 102 - Yamaha R6 Forum: YZF-R6 Forums
post #1011 of 1056 (permalink) Old 09-30-2012, 06:39 PM
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
Ok so my TPS was reading from 0-55% only lol
So I went in and calibrated the TPS in my bazzaz at closed: 0.72V and open: 2.54V
Does this sound ok? Now the TPS guage reads from 0-100%
Sent from my SAMSUNG-SGH-I997 using Motorcycle.com App
bluerebel is offline
post #1012 of 1056 (permalink) Old 09-30-2012, 09:14 PM
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
Never mind...found my solution.
post #1013 of 1056 (permalink) Old 10-05-2012, 09:49 AM
Re: All your Bazzaz Questions
I found that there is a weird problem with my ZFi and my 2008 R6.
I pluged the cable to ZFi and ran the engine in N gear. The RPM that i read form ZFi Mapper Software is always double (2x greater than) the true RPM from bike's instrument panel at any RPM. For example: In the iddle state, ZFi shows around 3000-4000 RPM when bike is at around 1500 RPM. So the normal fuel map based on RPM that be proceeded in ZFi would be totally wrong.
I rode my bike to the the technicians, they checked my bike and also read the same 2x RPM by their computer. The technicians told me they installed the ZFi totally correct and the problem is in the ZFi's wires, something is looped or so. And they don't know how to fix this. I had to ride my bike back home with disappointment.
So please help me to fix this. I confuse about this.
Thank you!
Cappy Hel is offline
post #1014 of 1056 (permalink) Old 10-09-2012, 06:49 PM
2010 R6 Looking for Mods
AWilchiwsky's Avatar
Tonight I uninstalled my z-AFM and took my bike to be dyno'd. For some reason any significant fuel changes makes almost no afr change. Has anyone else had this problem? Is it the bike or the software? Everything seemed fine when running with the z-AFM.
AWilchiwsky is offline
post #1015 of 1056 (permalink) Old 12-06-2012, 08:53 AM
Thank you!
...For so long, nobody has answered me
post #1016 of 1056 (permalink) Old 12-09-2012, 09:13 AM
jpaolo's Avatar
Bike: 06 R6
Have you calibrated the tps? (There are multiple thread on how to) Also is this the same tech who installed the unit if so try another tech. Also if you can check it out your self check the tps wire if its connected to the right tps. 06 and up r6 have two tps one in the middle and on the right side. The right side is the correct tps and its a grey wire. Good luck.
jpaolo is offline
post #1017 of 1056 (permalink) Old 12-09-2012, 11:14 AM
My R6 eats Fords
Bike: 2008 R6-R
Hey guys so I'm a noob when it comes to bikes. I bought mine an 08 and have just recently started to upgrade. I've done a lot of reading through the forums and have decided on a set up but don't have the cash to buy all at once. I have purchased a K&N filter, AGG smog plates, bazzaz zfi and an m4 mid-pipe. I am currently in the process of installing the mid-pipe, I have installed everything else.
All that being said, I guess my question would be is there anyone with a similar set up with a map that might be a good starter map for me?
Or if someone has any suggestions, I'm open to all suggestions.
Thanks guys
RU1N-R6R is offline
post #1018 of 1056 (permalink) Old 12-10-2012, 04:21 AM
My problem is the RPM not the TPS value. The TPS seems show the correct value and i have calibrated TPS on The ZFi Mapper software many times but the RPM is still readed the wrong value.
I think may be the the Bazzaz ZFi was connected to the wrong wire but i don't know which wire.
post #1019 of 1056 (permalink) Old 12-10-2012, 08:06 AM Thread Starter
Riding his own ride...
gsxcorey's Avatar
Give Bazzaz a call and they will explain how to diagnose it and ensure it's correct.
Corey
gsxcorey is offline
post #1020 of 1056 (permalink) Old 01-01-2013, 06:01 AM
I took my 2007 r6 to the track to do some auto tuning. The high end tuned great, however the bike would die every time I came off the track.
When I got home and pulled up the modified map many of the low TPS values in the high RPM ranges were in the +60 range. Really?
Why would it do this? Easy enough to fix but every time I auto tune it seems silly to have to go in and manually change these values.
Thoughts?
Jredford is offline
Bazzaz installation: pics and editorials added Agg2001 How To's... 282 04-14-2016 07:44 AM
Exhaust questions big_easy Exhaust and fuel delivery 3 11-01-2014 09:12 PM
Bazzaz Map selector switch!!! rmerchant3 Exhaust and fuel delivery 14 09-26-2010 08:56 PM
Bazzaz AFM zac5876 Exhaust and fuel delivery 3 01-18-2009 01:17 PM
Bazzaz Z-Fi/AFM software question(s) Agg2001 How To's... 9 12-25-2008 06:34 AM
