Do I just suck? Is it all me? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 21 (permalink) Old 11-26-2012, 03:18 PM Thread Starter
My first bike was a 2010 ninja 250. I could push that bike to its limits, around curves I could take it way faster than I ever could take my r6.
What is it? The weight of the bike? I know throttle control is a big part of it. I really couldn't **** up with 250 as in give it too much has or down shift and not rev match correctly. I don't know what it is I just cannot get this bike over.
Sent from my iPhone using
FreakyStyley69 is offline
post #2 of 21 (permalink) Old 11-26-2012, 03:19 PM
Suk it, Lee
Ryan5544's Avatar
Re: Do I just suck? Is it all me?
Not used to it yet maybe?
Have you tried growing a set, and getting balls deep in the corners yet?
Ryan5544 is offline
post #3 of 21 (permalink) Old 11-26-2012, 03:22 PM
I can ban you
Mario J's Avatar
Bike: 2013 GRB STi
Images: 3
The ninja 250 is a very noob friendly bike // very forgiving, light and nimble.
The R6 is a straight up supersport // can be extremely unforgiving, light, and nimble.
Practicing on a track will help you come to terms with the R6.
I <3
Mario J is offline
post #4 of 21 (permalink) Old 11-26-2012, 03:36 PM
Meh
Fallis's Avatar
Bike: 05 R6, and other stuff
How much do you weigh, and have you done anything to setup the R6 suspension?
Fallis is offline
post #5 of 21 (permalink) Old 11-26-2012, 03:37 PM
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
get the suspension tuned. might have the front too low, or the rear too high. that would severely hinder your turn in speed.
Agg2001 is offline
post #6 of 21 (permalink) Old 11-26-2012, 03:48 PM
just don't care
Honey Badger's Avatar
Bike: '02 R6 (track); '05 ZX10R
Those two bikes are completely different animals - everything from handling, power, suspension, to smaller things like where the friction zone sits. The R6 has a pretty crappy power band for street riding IMO - works okay on track but with no tweaks the stock power band is pretty sucky for riding on the street.
Like others said, get the suspension set for you and the type of riding you do, that alone can make a huge difference, but there's still going to be a learning curve getting used to the shifting and power differences. I go through something similar each trackday since my streetbike ('05 ZX10R) and my trackbike ('02 R6) are very different. I spend more time on the 10 overall, and when I jump on the R6 I spend at least a couple laps just getting used to the bike again.
Honey Badger is offline
post #7 of 21 (permalink) Old 11-26-2012, 04:01 PM
Livin in Paradise
tamucc2004's Avatar
Bike: Changing Daily
A lot is weight. There is a reason on a tight track with the right person riding a 250 or a motard can smoke most of the fieldon 600/1000 at a reg trackday in lvl 1-2. Less weight is later breaking, more speed, less fighting the bike etc.
WFOriders.com
CMRA Novice #484
tamucc2004 is offline
post #8 of 21 (permalink) Old 11-26-2012, 07:16 PM Thread Starter
I'm 160lbs. Never touched the suspension.
post #9 of 21 (permalink) Old 11-26-2012, 07:18 PM Thread Starter
I know it's partially me, just sucks, I feel like I had way more fun on the 250. I have had the back end slip a bit on the 600. That never happened on the 250. Which therefore makes me a little nervous.
post #10 of 21 (permalink) Old 11-26-2012, 07:25 PM
Meh
Fallis's Avatar
Definitely setup the suspension for your weight. There's a how to in the suspension section, or bring it into a local suspension/race shop or go to a track day and have them set it up for you. That'll make a big difference. The stock setup is pretty wonky.
Other things to consider - what tires are you running? What pressures? What tires were you running on the Ninja?
What is the bike doing that kills your confidence? Is it hard to get it turned? Are you missing apexes? Is it running wide on the exit? Does it feel super stiff - like your riding a rigid frame chopper? Is it way too soft and floating around like a boat every time you hit a bump? Does it turn in / fall over way too fast and feel skittish?
What were the circumstances that you felt the rear slipping on the R6? Getting on the power? What was the temperature at the time?
There's a lot of details to consider. Things are a lot simpler on the 250, when you have a lot less power and can pretty much pin it without worrying about spinning up the rear tire.
Fallis is offline
Re-Do's Really Suck! Dubya Garage / Mechanical Help 2 03-30-2012 07:33 PM
Why do i suck? superskyliner Track Tech & Riding Techniques 24 03-24-2010 05:03 AM
Why do i suck? superskyliner Test section 1 03-12-2010 02:16 PM
I know....I suck... YamaDan General Discussions 21 06-29-2007 11:58 PM
