Wheelie Question!!!!! - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 24 (permalink) Old 11-15-2012, 07:52 PM Thread Starter
I Ride Dirty
aj.r6's Avatar
Exclamation Wheelie Question!!!!!
okay so i went out and tried and failed hard!
i didnt know what i was doing but now i wanna learn the right way
so last time i was rollin in 1st at abt 30mph and i pulled in the clutch and i completely let off the gas(like i said i didnt know what i was doing
) sat there for a lil bit then pulled the gas and let off the clutch and shit just 12oclocked on me was bad!
anyways now its back on the road so im trying again! i really wann do this
so am i suppose to be going in first at abt 30mph and just slip the clutch and keep on the gas and drop the clutch?? how much rpm to give it before i drop the clutch???
oh and i have a 2006 R6s if that matters!
thanks
aj.r6 is offline
post #2 of 24 (permalink) Old 11-15-2012, 07:56 PM
Rocky5000100's Avatar
Bike: 2003 Track SV650, 05 R6
Re: Wheelie Question!!!!!
thanks
It does. The R6s can't do wheelies.
In all seriousness though: 15 mph in first, start accelerating, pull clutch in with one or two fingers, release, profit. Cover that rear brake so you don't loop it again.
Rocky5000100 is offline
post #3 of 24 (permalink) Old 11-15-2012, 07:59 PM Thread Starter
I Ride Dirty
aj.r6's Avatar
well that sucks! i looped the thing that cant wheelie ? lmao
what rpm do you suggest i go up to after i pull in the clutch??
aj.r6 is offline
post #4 of 24 (permalink) Old 11-15-2012, 08:01 PM
OnTheMove's Avatar
Dude id stay away from first... throttle is too sensitive!!!
Insert Motorcycle App. signature here
OnTheMove is offline
post #5 of 24 (permalink) Old 11-15-2012, 08:05 PM Thread Starter
I Ride Dirty
aj.r6's Avatar
yea i think thats why i did that i wasnt sure! what do you recommend 2nd? how fast and rpms??
aj.r6 is offline
post #6 of 24 (permalink) Old 11-15-2012, 08:08 PM
Tron has corrupted me
BigShepp's Avatar
Bike: 2005 R6 Raven "Deimos"
6000rpm in first and completely pops the clutch. That did it for me on my 05.
Sent from my iPhone using
Hard work yields great rewards, but idle talk leads only to destruction.
Proverbs 14:23
“Faster, Faster, Until The Thrill Of Speed Overcomes The Fear Of Death.”
Hunter S. Thompson
"It wasn't until I went to college and I got my first motorcycle that I understood the thrill of speed."
Vin Diesel
BigShepp is offline
post #7 of 24 (permalink) Old 11-15-2012, 08:10 PM
OnTheMove's Avatar
When i was learning to do them i would be in 2nd gear, go full throttle, slip the clutch at around 6k (still at full throttle) and would have trouble keeping it up because id accidently keep backing off the throttle.
If i were you id try 2nd gear at 10k rpms all full throttle and slip the clutch all at 100% full throttle.... i know it sounds crazy cause you will be doing like 70 mph but the more momentum forward you have the harder it is to 12 o clock it (atleast for me). If that doesnt work lower the rpms a bit. After awhile you can play with the rpms and throttle to get it up at lower revs.
post #8 of 24 (permalink) Old 11-16-2012, 08:07 AM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
Try this:
1st gear. Sitting or staggered, doesn't matter. Roll at 5-10 mph. Same time: BLIP clutch and turn throttle to 50% = HOLD the throttle steady (don't back off or give more gas)
If it comes up to high and you OH SHIT moment. tap the rear brake. if it doesn't come up high enough, repreat with more throttle input.
Take babysteps till you get there.
R6/R1 hybrid
ridick_bowen is offline
post #9 of 24 (permalink) Old 11-17-2012, 04:14 PM Thread Starter
I Ride Dirty
aj.r6's Avatar
aight thx guys tryin it veryy soon !
aj.r6 is offline
post #10 of 24 (permalink) Old 11-17-2012, 04:25 PM
live to ride
mknuchell's Avatar
Bike: 07 R6 charcoal
Send a message via Skype™ to mknuchell
You can also search he forum a little bit an find countless threads on this topic...
mknuchell is offline
wheelie fun + question blindboy2k1 Stunters Corner 8 12-17-2008 01:20 PM
wheelie question... tigersport16 Stunters Corner 13 04-21-2008 07:24 AM
wheelie question erx_lo_es General Discussions 12 06-03-2007 10:46 AM
Wheelie Question zanatos1914 General Discussions 27 05-01-2007 08:19 PM
wheelie question... Phatcow General Discussions 1 02-04-2007 11:26 PM
