Stopies - Page 4 - Yamaha R6 Forum: YZF-R6 Forums
post #31 of 48 (permalink) Old 11-18-2012, 10:09 PM
Stunt Rider
ridick_bowen's Avatar
Bike: R6/R1 Hybrid
Re: Stopies
Question: At BP are you making a lot of body position shifting? Forwards and backwards with your torso? Or are you just manipulating the brake lever only.
Sometimes I come up nice and it feels like BP but it's not. But, my form is good, I think. Head up looking forward to where I want to go. Slightly off the seat with minimal brake input. But I tend to shift my body around a lot.
R6/R1 hybrid
ridick_bowen is offline
post #32 of 48 (permalink) Old 11-18-2012, 10:17 PM
vegasrider2005's Avatar
Re: Stopies
My second pic is almost perfect form. I need to look up a bit more bit good other than that. I'm not at bp in either pic. Still a little low but that is a safe height for me to roll at unless I'm really pushing for distance. Only time I use front or back body movement is in the pick up I pull up with my knees or when I start going over frontwards and have to such close to the bike. <-- not fun. Haha other than that its pressure on the bars and tank to steer
vegasrider2005 is offline
post #33 of 48 (permalink) Old 11-18-2012, 10:37 PM
Stunt Rider
Bike: R6/R1 Hybrid
Re: Stopies
Sounds like my pick up is good then, I do the same thing with my body and knees. So I can assume that I'm nowhere near BP then. That's a relief cause I can get over the mental block of flipping it.
I just need to bring it up higher intially rather than plowing into it then rolling.
More practice........
R6/R1 hybrid
post #34 of 48 (permalink) Old 11-18-2012, 10:42 PM
Re: Stopies
I have yet to flip a strait stoppie. I roll over the front sometimes doing a 180 or get tossed doing kangaroo but the strait ones I've been lucky.
post #35 of 48 (permalink) Old 11-18-2012, 10:50 PM
Stunt Rider
Bike: R6/R1 Hybrid
Re: Stopies
Kangaroos????
LIKE A BOSS!!!!!!!!!!
R6/R1 hybrid
post #36 of 48 (permalink) Old 11-18-2012, 10:53 PM
Re: Stopies
Brraaapppp
post #37 of 48 (permalink) Old 11-18-2012, 11:04 PM
Stunt Rider
Bike: R6/R1 Hybrid
Re: Stopies
Show off!!!!!!!!!
Do you recommend a steering damper? I know I need one but I'm only/still approaching at 30-40 mph.
Heard you only need them once you approach at 50+mph.
R6/R1 hybrid
post #38 of 48 (permalink) Old 11-18-2012, 11:12 PM
iRun
pickpocket293's Avatar
Bike: Wal-mart 12-speed
Re: Stopies
How in the fck is that possible?
  • What's the difference between an R6 and an R6s? HERE
  • Should I start on a 600 or a 250? HERE
  • How do I ask the forum a question and actually get an answer? HERE
  • Where do I find a map for my Bazzaz? HERE
  • Should I get a 520 kit for MOA POWAH? HERE
  • How does rotating mass work? HERE
pickpocket293 is offline
post #39 of 48 (permalink) Old 11-18-2012, 11:17 PM
Re: Stopies
Damper is deff a good idea. I was rolling 200+ without tho. Just low pressure helps keep the shake out.
And turn in super hard jab brakes hold on.
post #40 of 48 (permalink) Old 11-18-2012, 11:19 PM
Re: Stopies
This is a start to a kangaroo. At this point I just grab the brake hard and it whips around and get about 8" of air.
