My 03 R6 doesn't idle high when it's cold. I'll start it and it will sit at about 1100 RPM and then idle up to 1300 and stay there. My buddy's R6 idles at like 2k until it hits 104*F. It's pretty damn annoying since it takes 357128395 minutes to warm up.
Is there a high idle servo or something that needs to be adjusted? Or a sender that controls idle that is bad? Any ideas?
I've tried that too... The idle still falls right back down to 1300. I usually hold the throttle open at 2k until it warms up to speed the process up a bit.
there is a cold idle thing(for lack of the known term)
there is no pictures of it on parts diagrams even. it's like a secret or somthing yamaha doesn't let out.
anyway it's attached to the throttle body setup. it has two coolant lines connected to the rear of it.
and a single screw with a spring. I've never played with it, but it's job is to raise the rpm when it's cold.
now, yours could be bad, needs adjustment, or just need some lube on the slide plate. when you have a look at yours you will be able to see what I'm talking about.
it should move freely.
but like I said, on parts diagrams there is no picture of it. I highly doubt you can purchase it seprately.
Hello, this is my first time on this forum. Im having some issues with my Yamaha R6 (2005) after winter storage, everything worked fine last summer. The motorcycle was placed on the back of a car trailer with roof for about 5 months. I topped of the fuel tank with fresh gasoline before...
no idle whuntil warm thats the first sign my valves are needing adjusted only time i have that problem but 08 r6
Related Threads
3.1M posts
112.1K members
Since 2003
