I’ve decided to part out my 2003 Yamaha YZF R6 Race Bike, so I can get some money towards a newer race bike for next season. Almost all parts will fit a 2003-2005 r6 or 06-09 r6s. Some parts even carry over to a 06-11 r6. Check before you purchase though! Bike only has 3596 miles on it. 1500 were street miles. Always well cared for.
Prices do not include shipping, but give me your zip code and I will estimate shipping for u. specific pictures are available upon request. email me at carlsoltisz@yahoo.com or text 248-895-2715. you can also pm me or reply to this thread. I will do my best to get back to you asap. Open to offers and trades, but prefer cash.
New lower prices! Here is what I still have left….
Frame w/ salvage title $750
Rim/Tire Set w/ NEW Bridgestone BT-003Pros and rotors $500
Penske Double Rear Shock $500
PCIII $200
Subframe $150
Front Rim w/ dunlop good for trackdays $100
Jardine Slip on Exhaust (Some dents and rash but useable) $100
Dented Blue Fuel Tank Has fuel pump Useable Great spare $100
09 Tail light bracket $10
OEM Stator Cover Light Scratches $40
(3) Turn signals $20
Passenger Pegs $50
Vortex silver brake lever New in package $30
(7) Reflectors $15
Used swingarm spools light rash on one $5
Swingarm Axle bolt w/nut $10
Swingarm linkages $25
Rear fender $10
Wiring Harness $50
ECU $75
Rectifier $35
Battery $25
12in goodridge steel braided brake line NEW $10
4 ft goodrdge steel braided brake line NEW $20
Rear Brake Caliper w/good galfer pads $40
Rear brake caliper bracket $10
Rear Brake Master cylinder $20
Rear Brake Fluid Resivoir w/hose $5
Front Brake Fluid Resovior $10
Front Calipers w/ new brake pads $100
Swingarm, a few scratches/rub marks $50
OEM Facotry Service Manual $30
SS Kit Manual $20
Rear wheel Sprocket Hub $10
Speedometer Gauge (Surface scratches on tach, but funtional) $50
BVP Swingarm Spools NEW IN PACKAGE $25
Right Side OEM Rear Set $40
Left Side OEM Rear Set Broke but useable peg $30
Clutch Lever/Perch/Cable $30
10 Frame Sliders and hardware (Some Brane New, Some Used) $50
Black Frame Side Fairing pieces (Very light scuffs) $50
Left Aftermarket (Unsure of Brand) rear set. Broken Shift Lever, but good Mount and heel guard) $40
Triple Tree Fork Brace Both Upper And Lower $100
Brand New OEM Front Brake Pads (Both Sides $50
Front Rotor Set $50
Silver Vortex Right Side rear Set Mount Piece (light damage) $15
K&N Air Filter $40
Stock OEM Undertail and Brakelight $50
Silver Stock bodywork (Both Lowers, tail and windscreen) $150
Stock Fork Springs $10
Ram air tubes $40 for pair or $25 ea
Ram air rubber tubes $20
Black Fork Fairing piece $10
Clutch lever/perche/cable $25
Front Brake Lever knob adjustable $15
Front Brake Lever Wheel Adjustable $20
Throttle Housing/tube/grip and cables $35
GYTR Carbon Fiber Exhaust Bracket $50
Throttle Cables 10
Cush Drive set $10
rear wheel axel & Nut & adjustment blocks $20
Mychron Lite Laptimer with pickup (needs light work) $100
Front Brake Lever $10
Clutch Lever $10
Various aftermarket shift rods $10 ea.
Aftermarket Pegs (Unsure of Brand) $25
Renthal 520 48T rear Sprocket $20
Graves (I think) Billet Right Side Engine Case Cover (light rash) $50
2001 R1 ECU $50
Pair of Tokico Front Calipers (unsure what bike theyre for) $60
Front Brake Master cylinder (unsure what bike its for) $25
Brake Fluid Resivor + Hose (unsure what bike its for) $5
Yamalube Full Synthetic Oil Change kit NEW 1 $50
Yamalube Full Synthetic Oil Change kit NEW 2 $50
Yamalube Full Synthetic Oil Change kit NEW 3 $50
http://www.flickr.com/photos/68308859@N08/6209415127/in/photostream
PCIII $200
Subframe $150
Passenger Pegs $50
(7) Reflectors $15
Rear fender $10
Wiring Harness $50
ECU $75
Rectifier $35
Battery $25
SS Kit Manual $20
Front Rotor Set $50
K&N Air Filter $40
Throttle Cables 10
Cush Drive set $10
Clutch Lever $10
2001 R1 ECU $50
