So long story short.
Its a 2007 Yamaha R6r with integrated signals and flush mounts that were half installed.
Signals werent working when i bought the bike because a wire was wrong.
Seller told me to replace with all 15A fuses. I put in a 15A fuse into the SIGNAL spot(which is labeled 10A). Then i saw that the left side(clutch side) signals all worked now. Then the right side, and saw that only the front flush mount wasnt lighting up. So i saw two wires hanging down, a blue and a green, (the ground was already hooked up). I then connected the turn signal wire to the blue slot,(wrong one), and then i saw the electrical current jump. Then the rear lights and all were still working and it still wasnt lighting up. I tried the green wire and it still didnt work. Then i tested the blue one again, and it did the same thing and i was switching back and forth and then it completely stopped working.
Now NONE of the signals light up. Not even the green turn lights in the gauges not the brake light.
I checked the 15A fuse and it was fine, replaced it with another 15A and it still didnt work. Thats when i realized it is supposed to be a 10A fuse. So i put in a 10A, tried it and nothing. Reset the battery, nothing.
What have i done!?
and how do i replace what i have broken!? What is broken!? helpp
The bike still starts up and everything. Just none of the signals work.
Thanks a lot in advance
Im a dumbass. Today has been a longgg day...
What have i done!?
