if u wanted to run stock pressure i think it is somewhere around.....
36 front
42 rear
check ur owners manual for exact if u want stock keep in mind u may have better traction w/ a few less psi
Being a new bike owner you should read the owners manual before you even get on it. And in this "owners manual" you will find the tire pressure. As well as on the bike itself on a sticker on the swingarm.
198 lbs and under load-F 36 psi, R 36psi
198 lbs and up load-F 36 psi, R 42 psi
Srry, I'm just gettin sick of seeing all the stupid questions asked that can be answered easily by opening a book.
the_gill, good point. and fyi, i did get a ways into the book and my wife put it somewhere when she was cleaning and totally forgot about it. Thanks for reminding me to read it.
It all depends on how you ride. If you ride hard and hit up the twisties then you'll want to lower your pressures to say 32 to 34 rear and say 33 to 35 for the front. A good all around street pressure is in the neighborhood of 36R and 38F. Of course that will to high for most of us, but it's a good street pressure to start with if your new. I would not run your tires in the low 40's. Remember, as your tires heat up the pressure will increase. Lower pressures will give you more traction as a rule.
If you're riding the bike hard in the canyons I wouldn't recommend anything higher than 34f/32r and that's pushing it, imho. Play with the pressures and see what you like ... but certainly don't go over 36/36 (unless you're planning on 2-up).
I'm not sure if you do this, but I normally stand on the rim of each tyre before going on a ride. While its not as accurate as actually checking the pressure with a gauge, it will give you an idea if you need more air in there.
34 psi is still kind of low for street riding. If you commute on a daily basis, then 34 lbs will give any tire a flat spot. I pump up my BT014's to 38-40psi for freeway/work commuting and 32-34psi for canyons.
On cold track days: Jan 06-Buttonwillow and Dec-03-Streets of Willow, I've dropped down as low as 30/29 and two good solid warm up laps.
**It all boils down to where you're riding and how hard you're riding. ALWAYS check your tire pressure BEFORE riding!!! You can also double check it after a ride to see how much it increased in pressure** :fact
I would agree with you on this, but these tires aren't exactly endurance tires. They're going to go flat whatever you do (if all you do is commuting). Better to get the best traction out of them imho.
Related Threads
3.1M posts
112.1K members
Since 2003
