Compression and oil pressure gauges and adapters
985 views 0 replies 1 participant last post by  branko
#1 ·
I'd like to do the compression and oil pressure tests on my 03 R6.
According to manual, i need few "special" tools and adapters. I had no luck using Yamaha codes to find the correct tools in past because they are either non-existent or non-USA codes. Dealers are confused as well and they usually refer to K&L as the Yamaha official tool supplier. No luck finding any correct tool with K&L.
Anyway, i think Motion-Pro sells the compression tool, but i've no idea what adapter will i need (10, 12 or 14mm)?
What about the oil pressure, do i need a special gauge and where can i get the correct adapter?
Thank you!
B.
