Need Help from Electrical Gurus
898 views 7 replies 5 participants last post by  bmxguy08
#1 · (Edited)
So my headlights are set up like misterjj's diagram on post #15 http://http://www.r6-forum.com/forums/showthread.php?t=79940&page=2.
The problem is that my low beam sit, low beam keeps blowing out. I'm getting sick of opening the headlight up and replacing the bulb. (I have a dual headlight mod in) The bulbs that I'm using are: link
The only thing that is different on misterjj's diagram is that I have the LED (audi lights) connected to the relay and the there is a push button switch for the low beams, but they are still controlled by the autoswitch.
#5 ·
It's not that the bulbs are not clean. They are MR16 LED bulbs with a lens over the LED. Links are fixed and the fuses are OEM recommended. I was wondering if I have to put a resistor in some where b/c the bulbs are LEDS???
#8 ·
that sounds sketchy whatever you got going on there. try bypassing that push button BS u got going on there and try it that button could have an internal short or somthing.
you definantly have a short somewhere usually its always linked to something installed incorrectly or shitty aftermarket parts.
