My 01 is still messing with me lmao. I did a bunch of maintenance on it and the carbs. The only thing i havent messed with yet is the caps that cover the screw that adjusts the mixture.
I have a yoshi exhaust and a k&n air filter. I know i need to revert back to the OEM filter, but i was wondering if i need to drill out these caps and adjust the mixture of the carbs. It's running really rough in the low rpm range then it clears up in the mid-high. I've synched the carbs,cleaned all the jets and recently cleaned my air filter. I'm wondering if i should drill the caps out of the carbs and adjust the mixture screws...what do you guys think???
Thanks.
Thanks.
