I have a 2004 R6 it was wrecked and I have just finished putting it together. It will only idle at 3-4 K RPM. I have backed off the idle screw to where it's not even touching. I have also installed the shorty can from the 06-09 I am pretty sure it had had no mapping or other mods. Any suggestions would be great thanks. I also had the stator open because the cover was broken and loosened the rotor that connects to the crank. I am not sure if that has anything to do with the idle. Also I have noticed that the black slide is not compleatly shut but the butterfly is. Thanks
