Hey guys, last month I topped up fuel in my 2004 R6 added stabilizer and put it on a rear stand for winter. Its stored in an unheated garage.
Today I went to start it up and it wont start.
It just keeps cranking then sounds increasingly bogged down.
Granted it is around 23 degrees here in columbus ohio right now but I think that it should start regardless.
Shouldn't be the cold but I'm not sure what it could be.
The couple of times I've started mine when it's cold I haven't had an issue. How's the battery? Have you cranked it to the point where maybe you have drained it?
thanks for the quick replies, i didnt give it any gas when starting...but i do think it is the battery as it is cranking less and less. Bought a battery tender online, im hoping that will take care of it.
Yeah DON'T jump it with a car or a car battery booster either. Previous owner did that to my bike and fried the battery. Luckly nothing else was harmed.
Sounds like low battery volts, but it could also be a combination of the oil being cold. In cold temps oil is like honey. (depending on what oil you're using)
Similar story here, I rode my bike the day before and yesterday after running it briefly the day I got back from a 3 week vacation. The temps have been low 30-40s but today the bike turned over a couple times but the battery stopped cranking.
I am thinking I am just down on juice, but it could be I need to replace the battery as the bike has 20K miles on it. How do you go about charging/testing a bike battery anyway? Should I just pop it out of there and take it to a bike shop?
yeah its best to have it on a tender. Something about starting it once a week is bad because of condensation builds up in the oil and stuff. Ive got Sta-bil in it with the battery on the battery tender.
batteries lose quite a bit of their CCA's when left in the cold. my Harley is on a tender now.... have to install a connector to the R6 and get that on soon.
So my battery tender arrived today, took off the seat to see the battery strapped in there. What next do i just clamp the connectors on or should i use the more "permanent" leads that came with the tender? Also any tps to not electrocute myself or fry the bike?
I know im a total rookie at this :sing
thanks
Connect them somehow (permanent or alligator clips) then plug it in and follow your tender's directions. Don't lick the black at the same time as the red.
Related Threads
3.1M posts
112.1K members
Since 2003
