Rear Shock Spring : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 01-28-2010, 06:42 PM   #1
Sizerp
Tinkering...
Sizerp's Avatar
Bike: 2007 R6
Rear Shock Spring
Is possible to paint or buy an aftermarket stock rear spring? My bike is blue and my spring is red! I want them to match, or at least have it black.
Any suggestions, without replacing the whole shock system?
Thanks.
Sizerp is offline   Reply With Quote
Old 01-28-2010, 06:44 PM   #2
T-1
Thanks for playing.
T-1's Avatar
Bike: 2010 Roubaix S-Works
Re: Rear Shock Spring
In on 1
T1
T-1 is offline   Reply With Quote
Old 01-28-2010, 07:02 PM   #3
CosmoK
Resident JMU Wizard
CosmoK's Avatar
Bike: 08 R6/08 Duc 1098R #303
You can certainly paint the stock spring. That is your cheapest & easiest route.
2008 R6 fully worked by Barton Racing. (thanks Ray!!)Closing in on 130 rwhp... complete custom Ohlins/Racetech suspension.
CosmoK is offline   Reply With Quote
Old 01-28-2010, 10:16 PM   #4
mikey c
mikey c's Avatar
Bike: 2008 yamaha r6s
does anyone know how much it costs to switch the internals of the rear spring for a olins setup and what are the advantages over stock for daily driver with freeway fun in mind
mikey c is offline   Reply With Quote
Old 01-29-2010, 05:59 AM   #5
DanQ
Yamaha Blue in any color
DanQ's Avatar
Bike: FZR-1K, R1, Vmax, R6
Thanks.
Paint. Or have the spring replaced with one that is proper for your weight.
I don't think you can put Ohlins internals in a Kayaba shock. But companies such as Race Tech, Lindemann Engineering, Traxxion and others can install new valves and springs if needed.
For commuting and general riding your best bet is to have the suspension set for your weight/riding preferences before you start putting thousands of dollars into components you don't need.
Dan
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
05 V-Max 0098/2000 20th Anniversary
04 Roadstar Warrior
TEAM: SO FAST SO CLEAN
DanQ is offline   Reply With Quote
Old 01-29-2010, 06:14 AM   #6
longbrake_00
08 Yamaha R6
longbrake_00's Avatar
Bike: 08 Yamaha R6
You can have the shock powdercoated.. I had my penske shock coated to match the frame of my 650r. The spring was blue.
Mods:
Full Leo Exhaust, PC III, Graves Smog Block Offs, GYT-R High Flow Filter, Barnett Race Clutch, Vortex Sprocket Conversion, DID Racing Chain, GPR Steering Damper, Smoked Galfer Brake Lines, Samco Coolant Hoses, Carrozzeria Rims, Pazzo Levers, Moto-R Engine Covers, Acumen Gear Indicator, Bohemian Racing Rear Set, Speedo Healer, Graves Frame Sliders, Moto-R Spools, Knight Rider/Solid Third Eye, Gorilla 7017 Alarm, Graves Bar Ends, CRG Hindsight LS Barend Mirror, Spider Grips, Pro Bolts Fairing Bolt Kit, Lightech Engine Bolt Kit, Solo Cowl, GYT-R Black Axle Adjusters, Hotbodies Flush Mounts, Graves ExUP Removal, Puig DB Screen, Cox's Radiator Cover, Fender Eliminator, CA Tail Light, Lawstcaws Frame Plugs, Passenger Peg Covers, Stomp Grip Pads, Black Kickstand, Harris Gold Gas Cap, Carbon Tank Pad, Lightech Gold Oil Cap, Light N'Boltz, Puig Toe Guard, Race Rotors, Lamin-X Headlight Covers, Traxxion Tank Sliders, R&G Exhaust Slider, Rizoma Front and Rear Axle Sliders, PlanetSuperBikes Number Plates, Vortex Mirror Block Offs
longbrake_00 is offline   Reply With Quote
Old 02-03-2010, 12:32 PM   #7
BHR6
cruisin for a bruisin
BHR6's Avatar
Bike: 08 R6
Images: 3
I have a yellow spring that I want red also, how easy is it to take of the spring from the shock? I can send it to longbrake to powdercoat mine, but have no idea if I have to clamp the spring to get it off or not.
BHR6 is offline   Reply With Quote
Old 02-03-2010, 02:26 PM   #8
BlueDevilD
DARC Racing
BlueDevilD's Avatar
Bike: 06 R6 50th/Raven Hybrid
Images: 1
I wish the shock wasnt such a pain in the arse to get out. I have a Red spring on my 2006 and Id trade someone with a yellow spring. Im not sure if the 06 and 08 shock are the same. I know the forks are not.
June 2010 Ride of the Month!
Sig. Courtesy of GIJoe007
Dion's Sponsorhouse
Sponsors:
Rief Resources Media/Rebellion Motorsports /
Lockhart Phillips / Factory Backing / GoPro Camera
BlueDevilD is offline   Reply With Quote
Old 02-03-2010, 06:40 PM   #9
f1aws
f1aws's Avatar
Bike: 08 R6
The 08 shock IS different than the 06-07.
-Performance
Full M4 Carbon Exhaust
Smog Block Offs
Power Commander III USB - Custom Map
BMC Track Filter - Air Intake Mod
520 Conversion - 15/47 (-1,+2) Driven Sprockets - Black/Gold EK MVXZ Chain
Spiegler Black Steel Braided Front and Rear Brake Lines - Spiegler Black Banjo's and Banjo Bolts
-Appearance/Accesories
Unstretched | Unlowered
Hotbodies Smoked Flushmounts | Clear Alternatives Smoked Integrated Taillight | White Third Eye Mod
Cobra Radar Detector | Fender Eliminator | GYTR Black Chain Adjusters | Shogun Bar Ends/Swingarm Sliders
Black T-Rex Front and Rear Stands | Black Windscreen | Raven Front Fender | Raven Air Box/Gas Tank Cover
Sixty61 Black Windscreen Spikes | R6-Forum Yellow Reservoir Sock | R&G Exhaust Slider | Shogun Frame Sliders
Powdercoated Shift Rod/Shift Lever/Gas Cap/Rear Brake Caliper Bracket/Nuts/Bolts/Brackets
Powdercoated Levers/Clip-Ons/Radiator Pipe/Rearsets/Passenger Pegs/Kickstand/Lowering Links
My Bike Pics Here /w Full Akra and My Leo Vince Pics Here and Unstretched/Unlowered /w Full M4 Pics Here
f1aws is offline   Reply With Quote
Definition of preload, rebound and compression dj1298 Suspension settings 11 05-20-2013 04:44 AM
Opinion on Hyperpro Combi kit (rising rate front springs & rear shock spring) JTRC51 Suspension settings 1 10-27-2008 10:06 AM
'06 R6 rear shock specs? R6Hooligan Suspension settings 0 09-16-2008 12:37 PM
03-06 R6 and R6 ohlins damper, ohlins shock, graves exhaust, vortex rear sets NICE yzfrone Bikes Parts For Sale 7 05-28-2008 10:58 PM
Ohlins and Fork Springs and Rear Shock Spring ambasnakeman Suspension settings 0 04-01-2007 10:33 PM
