bike wont go neutral plus dead battery now : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 02-15-2010, 02:59 PM   #1
Dye12
Im not sure what happened but i gave bike a wash then when i tried to start saw it was not in neutral so i clicked and couldnt get it to go.
Tried to get bike going to go into gear but it just kinda bogged. Battery dead now. Jumped using a car and when i went to turn on it went to neutral. Rode around in first around 4k rpm. When i came to stop it wouldnt go nuetral.
What am i missing here? Its a 2001 r6
Dye12 is offline   Reply With Quote
Old 02-15-2010, 03:09 PM   #2
jebova2301
I eat what my R6 cooks!
jebova2301's Avatar
Bike: 2003 R6, 1995 YZ-250
Re: bike wont go neutral plus dead battery now
is it going straight to second? not going out of first? how long have you been riding?
jebova2301 is offline   Reply With Quote
Old 02-15-2010, 03:12 PM   #3
Dye12
it feels like its in second now because it wont take off right and bogs. Not long but i know its not in first and cant get neutral
Old 02-15-2010, 03:17 PM   #4
upbak
I eat my r6
upbak's Avatar
Bike: 2006 Bluejay R6
You know 1st is down from N position, right? Not being an ass for the record. Just asking. Had a friend not know that and you said you haven't rode that long. You've tried rolling it as you shift through the gears and letting out the clutch until the gear catches? Then try to gear down again. Sometimes if the clutch is still in, it won't down shift until you let it out and let it catch. Could be bogging cause its in 3rd??
upbak is offline   Reply With Quote
Old 02-15-2010, 03:33 PM   #5
Dye12
yea i know first down, after i jumped it i got it into neutral. Rode around then when i was coming to stop tried to go into N but nothing.
Old 02-15-2010, 03:40 PM   #6
jebova2301
jebova2301's Avatar
nothing as in it wont come out of gear, or nothing as in it keeps going to the next gear?
Old 02-15-2010, 03:44 PM   #7
Dye12
pretty sure it just went to second because when i rode around i kept it in first. then went for neutral. Thats when i think it just went to second because it would bog when i tried to go. I can get bike to start with stand in and clutch in. The gear only goes up and down w/e it is
Old 02-15-2010, 04:03 PM   #8
jebova2301
jebova2301's Avatar
pretty sure it just went to second because when i rode around i kept it in first. then went for neutral. Thats when i think it just went to second because it would bog when i tried to go. I can get bike to start with stand in and clutch in. When i rode around i kept it in first.
you sound like a newer rider, so you may just be giving it a little too much pressure for it to hold in neutral. i remember when i got my bike, i had trouble with this. then i also had trouble when i got my mx bike. turn the bike off, but leave the key in the on position. now just move it a bit without pulling the clutch. it should only roll a few inches. in that few inches of back and forth motion, apply a bit of downward pressure on the shifter(still without pulling the clutch). you should feel it click. if not, you may already be in first. if it wont click down, do the same and try to click upwards. keep an eye on your gauges. see if the neutral light blinks for a second. when you find where it blinks between those clicks, you have neutral. now you just have to keep it there
and this just hit me. your bike MAY be converted to gp shift. in that case, all the gears would be backwards. click up once from neutral to get to first, and down to get to the rest of the gears. to figure out if its gp shift, look at the shift rod. if it mounts to the top of the shift drum(12 o clock), it is gp shift. if it is on the bottom(6 o clock), you are standard
Old 02-15-2010, 04:05 PM   #9
Busa
442 whp
Busa's Avatar
Bike: 2007 turbo Hayabusa
When the trans won't go into neutral: start the bike, LIGHTLY let out on the clutch until the bike gets into it's friction zone (begins to pull lightly). Pull the clutch back in and attempt to find neutral again.
Rockin' the land barge...
Busa is offline   Reply With Quote
Old 02-15-2010, 04:07 PM   #10
Dye12
Ill go try but yesterday i rode for 4 hrs and never had a prob getting neutral. And my gear box is 1 down 6 up. I went through all gears yesterday. Could my neutral switch not be grounded? If so how do i pull that out from back of engine?
could it be the battery? I keep having to jump it now
HOW TO: DIY lightweight battery Agg2001 How To's... 34 08-06-2013 08:10 AM
Dead battery or will driving revive charge? picass1850 General Discussions 8 04-29-2011 07:14 AM
Dead battery can't charge with battery tender jr. youngfido General Discussions 9 12-01-2009 03:18 PM
Battery Issue - Dead from HID's??? deadwood Garage / Mechanical Help 7 05-26-2009 02:25 PM
How To: Battery dead? Rolling start! gfraisse General Discussions 7 03-16-2007 07:00 PM
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
