R6 Service Manual and Diagnostic codes. : Yamaha R6 : R6 Forum
Closed Thread
Old 08-11-2004, 09:18 PM   #1
TexasR6
Supermod old school style
TexasR6's Avatar
Bike: 04 R6 White
Send a message via AIM to TexasR6 Send a message via Yahoo to TexasR6
If you get an error indication and a number on the LCD Display, this is what the numbers mean.
11 Cylinder identification sensor failure
12 Crankshaft position sensor failure
13 Intake pressure sensor failure
14 Intake pressure sensor pipeline failure
15 Throttle position sensor wire disconnected or short-circuited
16 Throttle position sensor stuck
21 Water temperature sensor failure
22 Intake temperature sensor failure
23 Atmospheric pressure sensor failure
24 Oxygen sensor failure
30 Lean angle cut-off switch activated
31 Maximum allowable Oxygen sensor correction level exceeded
32 Oxygen sensor correction level too low
41 Lean angle cut-off switch disconnected or short-circuited
42 Vehicle speed sensor or neutral switch failure
43 Monitor voltage -- less than 3v
44 ECU failure
RIP Keith Hamm. 1/26/2006
TexasR6 is offline
Closed Thread
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
