99 r6 idle rough & flat spot : Yamaha R6 : R6 Forum
Old 03-15-2010, 05:45 PM   #1
davsas
hi my 99 r 6 is rough on idle and has a flat spot on pull away, then pulls ok. Once going its fine, running very east and would not know there is a problem. Have spoken to a few people and they have said carb balancing. I have totally stripped carbs and cleaned every last bit off them. I have also replaced the plug leads to cancel out the problem being spark. But my garage says it is not a balance problem, though it has not tested it, thats just from my description of fault. Please if any one has an idea please share it with me, cheers dave
davsas is offline   Reply With Quote
Old 03-16-2010, 08:29 AM   #2
pox
Bike Newb =[
pox's Avatar
Bike: 2000 R6
Send a message via AIM to pox Send a message via MSN to pox
Re: 99 r6 idle rough & flat spot
Def sounds like a carb problem, Clean and sync.
(thats the answer to all our problems)
pox is offline   Reply With Quote
Old 03-16-2010, 08:34 AM   #3
Captscooter 954 R6
STOP PROJECTING ON ME@!!@
Captscooter 954 R6's Avatar
Bike: 2002 954, 2006 R6
or you could have it ran on a dyno with an AFR and see if u have a fueling issue.. be it lean or fat anywhere in the range..
2006 RAVEN-Full Yosh TRC Carbon System. Graves Block-Off Plates, PC3 USB, Shogun No-Cut Frame Sliders, Speedo Healer, Greggs Customs Front Flush Mounts. Powdercoated Pass. Pegs and Rearsets. Zero Gravity Clear Dubble Bubble. CRG Shorty Roll-A-Click Levers in Black. Michelin Pilot Power 2CT Front and Rear. EBC HH front Pads. Galfer Black Brake Lines. Acumen Digital Gear Indicator. GYTR Filter. Tuned Stock Suspension. Integrated Rear Turn Signals into Pass. Pegs with L.E.D.s
Captscooter 954 R6 is offline   Reply With Quote
Old 03-16-2010, 03:06 PM   #4
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
You can pull the spark plugs and look at the color of the tips to see if you are running lean or rich. rich will have a black tip on the plug, lean is white, and perfect is a light tan color.. Cheaper than the dyno, but not as accurate..
And most people clean and synch em and are fine afterwards.. If I just keep mine over 8k RPM's I have no problems.
CONTACT/EMAIL ME HERE
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
2000 R6 Wont idle when hot + ticking noise (UK) Borms81 Garage / Mechanical Help 1 12-16-2013 02:11 PM
'07 r6 won't idle cold. dumbydome Garage / Mechanical Help 3 03-02-2009 11:41 PM
03 r6 sputtering at idle, sometimes pops.. HELP! bowaplaya7 General Discussions 3 05-21-2008 09:43 PM
rough idle on a 99 r6 jjayson6 How To's... 7 10-03-2007 10:55 PM
rough idle?? chukiechz General Discussions 8 08-29-2003 01:50 AM
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
