2005 r6 frame up build : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Appearance and Exterior Mods
Old 05-01-2011, 09:53 AM   #1
Theory_EK
Bike: 2005 R6
Got this in a trade and decided to build it up. I need to know what noticeable parts am I missing. I know I'm missing motor, body work, clip ons, left rear set, gauge and headlight wiring harness, and hardware. Can you guys lmk the obvious of what I'm missing here so I can complete this project. Also I have some questions on what parts I have so I can label everything.
Frame, forks, swing arm, wheels, rear shock
Parts laid out
What are these?
Throttle cables?
Brembo?
All help is appreciated.
Theory_EK is offline   Reply With Quote
Old 05-01-2011, 10:18 AM   #2
Theory_EK
Bike: 2005 R6
Re: 2005 r6 frame up build
http://cgi.ebay.com/ebaymotors/03-09...Q5fAccessories
I'm thinking about pickin this up it says all the hardware is there does it look like it?
Old 05-01-2011, 10:28 AM   #3
adamb
I take my R6 on dates.
adamb's Avatar
Bike: 05' R6
As far as the brembo brakes, 05's came with brembo "lever bodies" (the actual word is on the tip of my tongue). hope that kind of helped.
adamb is offline   Reply With Quote
Old 05-01-2011, 05:47 PM   #4
Theory_EK
Bike: 2005 R6
Thanks for the info, no one has any info on the wiring or brackets in the pictures?
edit:I just found the parts list and service manuals for the r6 and r6s so I guess I have some reading to do to fin these parts.
Old 05-01-2011, 11:54 PM   #5
Mikey R6
My R6 gets me.
Mikey R6's Avatar
Bike: 2004 R6 SOLD, 09 R6r
Just FYI that's not a 05 front end
PSN: Mikey_YZFR6
Mikey R6 is offline   Reply With Quote
Old 05-01-2011, 11:58 PM   #6
JTolles
It's pronounced "Tollz"
JTolles's Avatar
Bike: 2007 R6, 2009 DRZ400SM
Send a message via AIM to JTolles
How is it not?
Sig by Joe
06-07 Street Parts here!!!!
JTolles is offline   Reply With Quote
Old 05-02-2011, 12:02 AM   #7
Panici
Knee drags YOU!
Panici's Avatar
Bike: '05 R6 + Vintage Yamahas
Images: 1
Originally Posted by JTolles View Post
How is it not?
'05 has inverted forks.
Mods: Armor Bodies Superbike bodywork, BT-003 RS, Renthal 50mm Clipons, Bickle warmers, etc, etc...
Gear: ATGATT down to the mouthguard.
A few vintage Yamaha bikes
Panici is offline   Reply With Quote
Old 05-02-2011, 12:03 AM   #8
Mikey R6
My R6 gets me.
Mikey R6's Avatar
How is it not?
Isn't the 05 inverted? Why would any one change it back
That looks like the front end on my 04
PSN: Mikey_YZFR6
Old 05-02-2011, 12:08 AM   #9
JTolles
JTolles's Avatar
Parts laid out
What are these?
Rear brake switch. it mounts on the right rearset
From what I can see: Dog bone, rear caliper bracket, rear brake lever, both rear sets, axle adjuster blocks
Throttle cables?
Yes
Axles
Ground wire. Goes from your battery to a bolt under the tank on the frame. The connector should plug into the ECU somewhere
No idea. Could be the speed sensor.
Looks like either injectors or fuel pump harness
Brembo?
Brembo master cylinder
My comments in RED
Also, I didn't see any front brake lines. I'll have some available by the end of this week if you need them
And I didn't see the shift linkage
Sig by Joe
Old 05-02-2011, 12:09 AM   #10
JTolles
JTolles's Avatar
Y'all are right. My bad. I was confused
Sig by Joe
HTML code is On
09/10 winter project..... 2005 R6 stunt build ADRENALINE RUSH Stunters Corner 42 09-09-2012 02:17 PM
wanted: 1999 - 2005 R6 frame and title, frame damage is ok, title can be salvage 1cheapr1 Bikes + Parts + Gear Wanted 2 07-09-2009 11:48 AM
WTB- 2005 frame sosickwitit99 Bikes Parts For Sale 4 04-01-2009 04:38 AM
FS 2005 R6 frame. R6_lover Bikes Parts For Sale 4 02-20-2009 10:11 AM
anyone need a 2005 frame with title? jwren Bikes Parts For Sale 4 10-03-2008 02:56 PM
