R6 FAQ, Fuel Controllers, Exhaust, Maps - Page 11 : Yamaha R6 : R6 Forum
Old 04-03-2012, 08:38 AM   #101
MinnesotaTA
Winter Toy, MXZ 800
MinnesotaTA's Avatar
Bike: 2007 R6
Re: R6 FAQ, Fuel Controllers, Exhaust, Maps
post 97 u said u were checking the TPS in the diag mode, ok cool.. i was telling u it will only do it once, then u have to start the sequence again.
U dont have to be / or shouldn't be in the diag mode to calibrate your TPS for the PCV, from what your saying it wont start. Just start the bike like u normally would, hit reset, WOT blips and save.
What was your TPS% saying when u watched it live?
-------------11.16@124 ------------------------No ET yet-------------------------------- 10.71@127 -----------------
MinnesotaTA is offline   Reply With Quote
Old 04-03-2012, 08:43 AM   #102
Mr. Azim
Mr. Azim's Avatar
Percentage shows as zero when I do it. It shows the voltage up to 0.733 or something, but no throttle % at all.
The other issue was that the bike won't start at all. keeps chugging but doesn't turn with either PCV plugged in or stock ECU in.
Mr. Azim is offline   Reply With Quote
Old 04-03-2012, 08:47 AM   #103
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
it will only pick up the TPS when the bike is running.... so gotta fix that first. i responded in your other thread. might have to reset the bike in the diag mode, thats what i had to do.
Old 04-03-2012, 09:30 PM   #104
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
Hey Ohio... You have the ignition module and quickshifter?
Old 04-04-2012, 02:58 PM   #105
OhioYJ
OhioYJ's Avatar
No, I've looked into it and for as much as it costs I think I will go to a flash tool or YEC ECM, as that ignition module is expensive.
OhioYJ is offline   Reply With Quote
Old 04-04-2012, 03:33 PM   #106
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
where do u get the flash tool? YEC ECM?
I just purchased, and currently installing the Ignition Module and Quick shifter. So, was curious to see what setting u had.
Old 04-04-2012, 05:33 PM   #107
Mr. Azim
Mr. Azim's Avatar
So I've fixed the code error and starting issue (thanks to Ohio and Minnesota) but now I have to configure the TPS..... I tried to put in the default values that Ohio suggested but it doesn't appear to be reading.
It looks like I have to use Minnesota's recommendation and do it while the bike is running. Because whenever I try to do it in Diag mode, the throttle sensor only goes to 50-something once, not reading in the PCV software, and when I switch it off/on the code 14/15 appears again.
If I wipe it it starts again. So Minnesota: Did you just start the bike normally with the PCV plugged in your computer, then open the TPS callibration tool in the PCV software?
So bike is running, open callibration, clear what appears, then open the throttle full, hit okay, turn the bike off/software should pick it up automatically?
I just want to try it once because when it was running the software was showing throttle at 100% (it was just idling) and the AFR was up in the 16's so I shut it off. I didnt want to let it run with it reading that high. But the AFR/RPM was reading when I pulled the throttle a little bit.
I'm using Ohio's PCV map and AFR table.
Old 04-04-2012, 05:43 PM   #108
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
yea.. the voltage got messed up in the TPS cal it looks like when u were messing with it so thats why its showing 100%..
Dont even worry about the DIAG mode on the bike anymore(for this).. So yea, have everything all plugged in, let the bike warm up, have your computer going so u can watch, open the TPS cal box, click on the reset button, blip the throttle WOT for a quick sec then save it.. Dont hold the throttle down to try and get the bar to move all the way across the cal box,,, it wont. Have you found this to read up on yet? And the AF's in the 16's isnt that bad.
open below link and click "To Calibrate the Throttle Position"
http://www.powercommander.com/powerc...tml/wwhelp.htm
Old 04-04-2012, 06:23 PM   #109
Mr. Azim
Mr. Azim's Avatar
Awesome.... worked great. 0% throttle when closed, 100% when open. And the AFR isn't as high.... it hovers around 13.5 to 14 but sometimes up to 14.5 at the highest (but not often).
Would it matter if I lowered my AFR target tables?
Mind you, this is warmed up in the garage. I need to take it around the block (but this is for track/racing so I will likely need to take it up there in a few weeks to play around with it). It still smells rich though.
Although the voltage on the TPS was noticeably lower than what was on here. 0.645 minium, I forget what the max was but it was lower than Ohio's 3.991).
Old 04-04-2012, 06:26 PM   #110
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
Although the voltage was noticeably lower than what was on here. 0.645 minium, I forget what the max was but it was lower than Ohio's 3.991).
The TPS voltage will vary from bike to bike.. the AF will bounce around a little bit, wouldnt worry about it as long as its not surging.
Any Air Traffic Controllers in here? Stingerz Off Topic Talk 10 05-27-2012 08:35 AM
PCIII maps .. custom maps, worth it or not? tekniqz Exhaust and fuel delivery 14 11-30-2008 04:20 PM
Differnce in Exhaust maps? +44 Exhaust and fuel delivery 9 11-26-2008 11:03 AM
05 pc3 fuel maps. fastvwjetta Exhaust and fuel delivery 6 09-06-2005 09:33 PM
'04 Fuel maps ??? R6#319 Exhaust and fuel delivery 1 05-27-2004 07:46 PM
