R6 FAQ, Fuel Controllers, Exhaust, Maps - Page 12 : Yamaha R6 : R6 Forum
Old 04-04-2012, 07:10 PM   #111
OhioYJ
OhioYJ's Avatar
Re: R6 FAQ, Fuel Controllers, Exhaust, Maps
Originally Posted by MinnesotaTA View Post
where do u get the flash tool? YEC ECM?
I just purchased, and currently installing the Ignition Module and Quick shifter. So, was curious to see what setting u had.
There's a company out of California making a device that allows you to tune, flash and modify your factory ECM, very similar to the YEC. It allows for changes to the fuel tables, throttle maps, ignition timing. I need to ask them if it has quick shifter functionality like the YeC. Currently this box is $400, but can be used over and over on multiple bikes. I've been hoping it would drop in price some after it had been out for a while.
OhioYJ is offline   Reply With Quote
Old 04-04-2012, 07:12 PM   #112
MinnesotaTA
Winter Toy, MXZ 800
MinnesotaTA's Avatar
Bike: 2007 R6
gotcha... wish i would have looked around more, didnt know what was out there and the DynoJet stuff was all i read about.
-------------11.16@124 ------------------------No ET yet-------------------------------- 10.71@127 -----------------
MinnesotaTA is offline   Reply With Quote
Old 04-06-2012, 10:13 PM   #113
MinnesotaTA
Winter Toy, MXZ 800
Bike: 2007 R6
well.. installed the Ignition Module and Quick Shifter.. Man that QS is fun!
Added 4 degrees of time at 100% and 2 degrees everywhere else, felt damn good and quick!
plan is to run 102 race gas and bump it up to 6 degrees, hitting the drag strip on Saturday.
Old 04-08-2012, 07:31 PM   #114
Mr. Azim
Mr. Azim's Avatar
OhioYJ.... after installing the MJS exhaust and letting it run, did it emit an odd/fume smell? I'm thinking it could be the powdercoat burning through.
Either that or it's running lean/rich. I haven't accepted any trims on the PCV/AT (if I do I would rather do it after a session at the track). I have the MJS map + the 13.8 to 13.0 starting AFR table you have in the first page.
Mr. Azim is offline   Reply With Quote
Old 04-08-2012, 10:30 PM   #115
OhioYJ
OhioYJ's Avatar
I don't remember any odd smells, on any of the MJS headers I've installed, but my nose isn't overly sensitive, so unless it was really strong I wouldn't have noticed.
Careful about accepting trims all over, you'll have a few spots that will continue to want.to go rich. I tend to only make adjustments to the cells that I think actually need adjusting. I also tend to throw the different maps and trims into a spreadsheet to compare the changes to, sometimes helps me analyze the data.
Old 04-09-2012, 04:57 AM   #116
Mr. Azim
Mr. Azim's Avatar
Good advice. There's a free dyno-run day at a local shop this coming weekend.... I might have it go for a run and see what the results are when they come back.
Old 04-09-2012, 06:04 AM   #117
OhioYJ
OhioYJ's Avatar
Also be careful with dyno results, as the dyno won't include the ram air effect.on our bikes, so it wont be entirely correct either.
Old 04-09-2012, 09:22 AM   #118
Mr. Azim
Mr. Azim's Avatar
Could it have anything to do with start up fuel? I haven't set any of that.... any recommendations? I would be using the time-setting (not temp).
Old 04-09-2012, 09:26 AM   #119
JTolles
It's pronounced "Tollz"
JTolles's Avatar
Bike: 2007 R6, 2009 DRZ400SM
Send a message via AIM to JTolles
Wow. Awesome write up man!
Sig by Joe
06-07 Street Parts here!!!!
JTolles is offline   Reply With Quote
Old 04-09-2012, 10:43 AM   #120
OhioYJ
OhioYJ's Avatar
So far on the R6s and CBRs I've worked on, I've never used the startup fuel. I also use the time delay not temp.
I would give it some run time and see if the smell goes away, could have been just something in the pipes. If it was really way rich or lean it should show up in your trims.
PCIII maps .. custom maps, worth it or not? tekniqz Exhaust and fuel delivery 14 11-30-2008 04:20 PM
Differnce in Exhaust maps? +44 Exhaust and fuel delivery 9 11-26-2008 11:03 AM
05 pc3 fuel maps. fastvwjetta Exhaust and fuel delivery 6 09-06-2005 09:33 PM
'04 Fuel maps ??? R6#319 Exhaust and fuel delivery 1 05-27-2004 07:46 PM
