Okay who can help me out? : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Appearance and Exterior Mods
Old 03-21-2005, 10:10 AM   #1
RedHot
Yeah that's mine
RedHot's Avatar
Bike: 03 R6
Okay guys I was wondering if you could help me out. Once you read this and then stop laughing maybe post up where I went wrong...
I got my headlights back and put everything back together, headlight assembly, front plastics, upper & lower side plastics ...
Problem 1 - I have 2 extra screws (identical but could not find where there are screws missing, anywhere)
Problem 2 - My Coolant Cover the lower screw will not tighten (most likely stripped the inside threads)
Problem 3 - I can't find my screws for my windscreen - Can I order just the screw?
Okay can anyone help me out?
Careful ... life might change around the next corner!
RedHot is offline   Reply With Quote
Old 03-21-2005, 10:23 AM   #2
Dan04r6
Bike: 04 Blue R6
Send a message via AIM to Dan04r6
hey,
screws can be bought at ur yamaha dealer, and the coolant is most likley stripped
Dan04r6 is offline   Reply With Quote
Old 03-21-2005, 10:26 AM   #3
RedHot
Yeah that's mine
RedHot's Avatar
Bike: 03 R6
I figured that much. The screw is fine so how do I fix it? Could I just get a nut to fit the back of it and try that?
Old 03-21-2005, 10:51 AM   #4
cowboy_r6
My R1 likes it fast!
cowboy_r6's Avatar
Bike: 02 R6 (SOLD), 2004 Red R1
Images: 1
The nut on the back would work, but it will be a bitch to get to and hold while you turn the screw. If I am not mistaken, there is a clip that clips onto the coolant bottle that is threaded. I would recommend just buying that clip and fixing it the right way. If you have extra screws, they more than likely go to the front "dash", the big black piece behind and on both sides of the speedo that hold all of the upper together. It's kind of hard to explain. I had to replace the whole front fairing and I had 2 extra screws on mine, come to find out there were two screws a little lower than the ram air tubes I had forgot about. They weren't in plain sight. Like mentioned already, you can just order the screw. My dealership told me it would take a couple weeks to get them, so I ordered them off of bikebandit.com for like .60 a piece. Got them in 3 days. Good luck.
-RIP Robert W. E. Anderson, US Army
-RIP Tom Rose
-God be with Garry C. W. Pruitt, US Army, Middle East
-2004 Red R1
Everyone has a Jekyll and Hyde, you just have to learn how to control Jekyll and when to let him loose!
"Life's tough, but it's tougher when you're stupid" ~ John Wayne
cowboy_r6 is offline   Reply With Quote
Old 03-21-2005, 11:13 AM   #5
RedHot
Yeah that's mine
RedHot's Avatar
Bike: 03 R6
Thanks a ton! I'll check out the lower section under the ram air. I don't think I looked there. I will also check out the web site!
Thanks again!!
HTML code is On
