Adust the Idle on 09 R6 : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > How To's...
Old 08-15-2011, 09:17 AM   #1
jcapstaff
My R6 eats ALL
Bike: 2009 r6
How do you adjust the idle or where is the idle screw located? Just curious. It does not say in the owners manual.
jcapstaff is offline   Reply With Quote
Old 08-15-2011, 09:31 AM   #2
S3aturnR
track junkie
S3aturnR's Avatar
Bike: 2009 Yamaha R6
Re: Adust the Idle on 09 R6
Originally Posted by jcapstaff View Post
Hi people, I have a 09 R6 that is currently running at 2krpm idle which is too high, any idea on how to adjust the idle? I do not know where the screw is nor does the owners manual say. Thank you.
are we sure that it's the idle adjustment screw that's causing the high idle or could there be an underlying issue that you'd effectively mask by messing with it? unless someone's already adjusted it, something else is likely causing the high idle. make sure you don't just fix the symptoms, correct the problem...
s3aturnr
...the 3 is silent
2009 yamaha r6
i give up...
S3aturnR is offline   Reply With Quote
Old 08-15-2011, 09:51 AM   #3
jcapstaff
My R6 eats ALL
Bike: 2009 r6
s3aturnr
I dont know of what problems there possibly could be. I mean the bike only has 3700+ miles on it and I have taken good care of it but at the same time only doing stuff such as checking bolts,cables,etc, change the oil, clean it, regrease the chain, things like that. As far as mechancial I have not done anything to the bike, I just had it inspected a few days ago, yet just noticed today that my bike is over idling. any idea of what it could be? The bike tends to go around 10mph on its on now which is kind of weird(unless I hold in the clutch or pop it in to neutral).
Old 08-15-2011, 10:01 AM   #4
S3aturnR
track junkie
S3aturnR's Avatar
it's definitely not normal, but i doubt that simply adjusting the idle will fix the problem. i can't even guess what it might be, but i've masked problems like that before only to have much bigger problems later on. i'd take it to someone if you're not able to trouble-shoot yourself. it's not fun to drop money on repairs, but i bet you'll be glad you did...
s3aturnr
...the 3 is silent
2009 yamaha r6
i give up...
Old 08-15-2011, 11:01 AM   #5
jcapstaff
My R6 eats ALL
Bike: 2009 r6
You know I feel kinda dumb. I mean the idle is fine sitting at 1400rpm, but what I guess I mean is it normal when in first gear for it to role at 8mph even though I am not giving it any throttle? I just rode up a hill(idle at 1400-1500rpm) at a matain speed of 8mph while giving it no gas. Is that normal?
Old 08-16-2011, 11:56 PM   #6
DESE
DESE's Avatar
Bike: 09 street, 09 stunt
try adjusting your clutch ?
Originally Posted by tfs32 View Post
Hit some cornors at 100+ and the Armour All will just melt off....
DESE is offline   Reply With Quote
Old 11-23-2012, 07:11 AM   #7
eaborda
Post Re: Adust the Idle on 09 R6
there is no idle screw on the 06 r6, its all electronic, the only way to increase the idle timing is by lifting the tank and on the bottom underneath all the hoses there are 4 breathing tubes with black plastic plugs, just remove a plug and that will increase the idle speed or plug them and that will decrease it, proved it yesterday, the famous screw that everyone talks about does not exist and the one situated between the plugs is not for idle, there's a thread somewhere about idle speed that the guy moded the idle spring and installed a screw, that one is just as effective as the plugs.
eaborda is offline   Reply With Quote
Old 11-23-2012, 08:18 AM   #8
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
holy crap man.. seriously?
you know what you removed? a vacuum plug! and now your bike is running lean and THAT is why your idle speed increased. Those plugs are removed to hook up a throttle body sync tool.
Of course if you lean out to a dangerous level the idle increases.. same as if you were to dump in huge amounts of fuel, the idle will drop. NEITHER are good for the engine. Running lean can cause the engine to run hot at best, and potentially detonate and damage the engine at worst.
You can't adjust the idle without having other bad after affects, except though the ECU. There IS a tiny alen head screw with small lock nut in the middle of the throttle bodies on the back side, between the block off plugs (the plugs you remove to sync throttle bodies).. that screw WILL raise or lower idle, but it is factory set and you will cause LOTS of problems if you mess with it. Trust me on this. SIX YEARS ago builders/racers were trying to do this accurately on the 3rd gen bikes, and some of us ended up having to get another set of throttle bodies.
if that screw gets turned even a slight amount, and it will have a large affect on idle but you won't see it right away even with the bike running. You might run the bike hard and then it's ideling at 5000rpm. You will try to adjust it a tiny amount, and next time out it's barely running when you let off the gas.
DON'T mess with that screw.. the only way to adjust a 3rd gen idle safely is with an ecu flash.
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 11-23-2012, 08:42 AM   #9
MELK-MAN
MELK-MAN's Avatar
as DESE posted, your clutch needs adjusted. should be very simple, there is an adjuster on your clutch perch. you have too much free play right now, and the small distance the cable is moved before your lever hits your grip, the clutch isn't disengaging enough. If you do have the correct free play, you likely have warped metal clutch plates. or, it's really cold where you are and the engine oil isn't warmed up just yet, and that is causing some drag among all the plates.. but likely is a cable adjustment considering the bike is literally moving forward.
Old 11-23-2012, 08:46 AM   #10
Tdub
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
I didn't think it would take long before you caught that!!
Tdub is offline   Reply With Quote
What should the idle be at Craig14122 Exhaust and fuel delivery 6 05-02-2010 09:13 PM
04 idle screw doesn't change the idle geeniusatwurk Garage / Mechanical Help 4 01-15-2010 09:05 AM
My first 99 R6 won't idle Whitehead'sr6 Garage / Mechanical Help 7 02-02-2008 04:08 AM
Adust idle? jc r6 Garage / Mechanical Help 9 08-26-2007 04:06 PM
Idle ? 2002r6 General Discussions 4 08-11-2006 03:45 PM
