TPS Diagnostic Mode : Yamaha R6 : R6 Forum
Old 08-21-2011, 06:58 PM   #1
Hellerox
Bike: Yamaha R6 2009
TPS Diagnostic Mode
Hi,
I tried to calibrate throttle position for my pcv+autotune like in this thread http://www.r6-forum.com/forums/showt...24#post2100524 so I followed the instructions entered into Diagnostic mode d01, twisted the throttle all the way and the max number that it reaches is 61, in his tutorial he mentions that the number should be close to 100. Is something wrong with my TPS?? Do I have to adjust something? What can I do?
Also in the PCV throttle Calibration window I don't see the voltage changing, only 0s, That isn't normal right??
*EDIT* without PCV everything seems fine in diagnostic mode
Thanks in advance.
Hellerox is offline   Reply With Quote
Old 08-21-2011, 07:10 PM   #2
OhioYJ
OhioYJ's Avatar
Re: TPS Diagnostic Mode
You should see the voltage changing in the PCV software, if it's not thats a problem. With the bike running when you rev the motor do you see any change in the TPS reading in the PCV software?
You might need to clean the TPS sensor connections, or you may have a created a bad connection when you hooked into the TPS wire when installing the PCV.
OhioYJ is offline   Reply With Quote
Old 08-22-2011, 09:31 AM   #3
Rossy
Bike: 2005 R6
Yeah there is definitely something wrong there. I checked mine not too long ago just for the hell of it and it read 96 at WOT. There is walkthrough HERE on how to clean the TPS on the second gens, I imagine it is similar to the r6r. I would clean it and try to test the voltage to see if it fixes things before getting a new one.
Rossy is offline   Reply With Quote
Old 08-22-2011, 10:16 AM   #4
Matt_M
Matt_M's Avatar
Bike: 06 raven
i did this last week and after i was in the dia mode it didnt read full either but i turned the key off and redid it..the second time i did it i got to the dia mode and then hit select i believe and it took it to 001 and then i calibrated the tps and it read 100
Current Upgrades
M4 midpipe
Graves Block off plates
Termi slip on
Bazzaz ZFi & ZAFM
Dunlop Q2
Graves EXUP eliminator
BMC race filter
Woodcraft frame sliders
15T Driven front sprocket
ASV C5 levers
Matt_M is offline   Reply With Quote
Old 08-23-2011, 10:09 AM   #5
dhanoon6
Member
Bike: '12 R6
You just need to adjust the angle at which your TPS is bolted on. Closed throttle should read 15-17, WOT should read 97-100.
dhanoon6 is offline   Reply With Quote
Old 08-23-2011, 10:20 AM   #6
r3x1mu5
zomething different
r3x1mu5's Avatar
Bike: 07 R6s
mine read 17 96 last time i checked. is this bad? could i adjust something so it opens up more?
...if i don't make it home today, god bless. dot cheers
r3x1mu5 is offline   Reply With Quote
Old 08-23-2011, 12:21 PM   #7
dhanoon6
Member
Bike: '12 R6
^ I actually have the same reading, i spent so much time fiddling with it trying to get it within spec but the best i could do was 17 96. You can always try to readjust it but I wouldn't worry about it.
Old 08-23-2011, 01:11 PM   #8
r3x1mu5
zomething different
r3x1mu5's Avatar
Bike: 07 R6s
cool, thanks for the info.
Old 08-23-2011, 01:50 PM   #9
Hellerox
I didn't see it when I was trying to calibrate the PCV, but I do see RPM and throttle changing when the bike is on and I rev it.
I'm going to check the connections.
Old 08-23-2011, 01:54 PM   #10
Hellerox
Where is the TPS??
I'll try this after work.
Thanks for all your responses.
Diagnostic Mode for 2007 cluster? R6xxer Garage / Mechanical Help 6 07-03-2011 05:49 PM
Diagnostic Mode???? D33PU Garage / Mechanical Help 2 04-21-2008 08:58 PM
Diagnostic mode R6 2006 Anthony00 Garage / Mechanical Help 2 05-28-2007 09:08 AM
Diagnostic Mode - What does "CO" mean? 666 General Discussions 3 05-10-2007 02:19 AM
DIAGNOSTIC MODE from OEM Cluster... IWannaBoost General Discussions 4 03-16-2005 09:59 PM
