Low Idle and Dies :( : Yamaha R6 : R6 Forum
Old 10-05-2011, 02:57 AM   #1
PUL58R
PUL58R's Avatar
Bike: 06 R6, 07 GSXR600
I am having trouble with my 2006 R6. On a cold startup its getting a really low idle, by low i mean 500rpm. So I give the throttle a twist and the bike isnt recognising that i have cracked the throttle and it will hold the revs there at around 500rpm but they will not increase. But if I release the throttle the bike will die. This isnt happening everytime I start the bike in the mornings but it is happening more often. Usually it will only do this once and the second time it will be fine, but this morning it took 5 or 6 times before the throttle would do anything to the engine revs. Also I have only put a BMC Air Filter and a Jardine GP1 exhaust that is all the mods that are done to the bike and it has 30000kms on it.
PUL58R is offline   Reply With Quote
Old 10-05-2011, 06:41 AM   #2
EJM05
Bike: 2009 R6 Raven
Re: Low Idle and Dies :(
check your tps
2007 Yamaha R6- Its got some goodies.
EJM05 is offline   Reply With Quote
Old 10-05-2011, 10:16 AM   #3
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
You probably need to retune the fuel map on the bike. If you don't have a fuel management system and you're running the BMC and Jardine, that could be your issue.
Is it cold in the mornings? And is it getting colder where you live like it is here (winter coming soon)? If so, that would indicate that it's lean, and in the AM it gets leaner from the cold, and the throttle bodies aren't hot enough to warm the intake air to the point where it richens up the mixture a bit..
CONTACT/EMAIL ME HERE
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
Old 10-06-2011, 01:45 AM   #4
PUL58R
PUL58R's Avatar
Originally Posted by EJM05 View Post
check your tps
Probably a noob question, but how do I check the TPS? Do I go through the diagnostic mode on the bike?
Old 10-06-2011, 01:49 AM   #5
PUL58R
PUL58R's Avatar
On the note of fuel management, I do believe that this may have part to do with it but also at the same time I dont think that this is the problem as these have been on the bike for about 4 months now and it only made the idle slighty lumpier as if there was a lumpy cam in the bike when cold. But no its not that cold over here right now we have started spring and the weather is getting hotter but in the mornings generally is around 14C. And yes it is only in the AM that its doing this.
Bike dies at idle while ridding. Paytheon General Discussions 43 07-17-2013 07:02 PM
Will not idle at the correct RPM, and DIES!! Meggerz08 Garage / Mechanical Help 20 09-21-2011 07:26 AM
HELP 06 R6 Will idle but dies when given throttle RAEOLIN Garage / Mechanical Help 0 04-29-2011 08:17 PM
Will not idle, drops then dies.... rvo0531 Garage / Mechanical Help 2 08-17-2009 03:58 PM
03 R6 Dies if I try to idle watchyouR6 Garage / Mechanical Help 10 03-19-2007 02:25 PM
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
