Agg Racing, NEW ITEM: SBK rear reservoir kit : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > Site Sponsors > Vendors and Group Purchases
Old 10-05-2011, 10:08 AM   #1
Agg2001
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
http://aggracing.com/store/index.php...&product_id=66
that's right... they're now available.
you can also buy JUST the tygon. $5.95/ft (and my "foot" is more like 13" and change - i suck at measuring but don't care)
This is a simple high-quality Agg Racing kit comprised of a hose clamp, spring clamp, breather cap, and clear hose. The hose clamp is a SS band (301 grade) with a SS screw (410 grade). The spring clamp is also SS (17-7 PH grade), and doesn't require any special too for install - a set of pliars and a good grip will work perfectly. An HRC (Honda Racing Corporation) branded breather cap will complete the hardware of this kit. The tubing is a highly chemical resistant Tygon 2375 tubing (1/4" I.D. and 3/8" O.D, 1/16" wall thickness) (2375 replaces the previous version, 2075), which won't crack, sweat, etc when in contact with even high corrosive brake fluid. This kit included 12" of tubing, and since the SBK rear reservoir only requires 8", the remaining 4" of Tygon can be used to update the front brake reservoir connection to match the newly installed rear reservoir.
i've done my very best to insure quality components to where there is NO wear/corrosion/rust on the parts used at any time, but can't promise it won't happen. i will guarantee them for 1-year from date of purchase, and will replace either/or clamp and spring clamp if needed. the HRC cap should be covered by Honda - so keep the HRC packaging.
the price of the full kit is $18.95 shipped. if you're not interested in the full kit, you can get JUST the clear Tygon tubing for $5.95/ft (with free shipping, as always).
i will always have a stock of these... so feel free to order whenever you'd like. IF the site is telling you it's unavailable at the moment, that means i'm very likely already waiting on Honda to supply me with another batch of breather caps. they can be slow from time to time. :|
edit: here's my how-to for this item... done on my bike.
here's MY "how-to" - it's nothing much, but there are a few "tricks" i figured out during the install:
what you get... and this is my tube already cut to ~7" for the rear part... leaving ~5-6" for the front tube replacement when i can trick a buddy into coming over and helping me bleed the fronts. :|
1. remove your old stuff... be careful of the fluid, as it's HIGHLY corrosive (protect the swingarm first, b/c i've seen, first hand, the damage this fluid can do if not cleaned correctly... a big ol' spot of raw aluminum) :|
2. slip the SS worm-drive clamp on the tube and then attach it to the master cylinder "in" tube. the trick to making the new tube g'awn (go on, for you non rednecks) smoothly is simple: find something to dip into the new brake fluid and then rub a bit of the residue inside that end of the tube - i used an old zip tie. slides in like a college chick. then
3. at this point you should have already cut the tubing to ~7-8" long... mine is about 7" (twss) and personally, it's just about perfect.
4. getting fluid in the tiny tube open-end is tricky - thank god for kids. i used a "medicine giver" or whatever it's called, and a little less than 5ml fills up the entire tube, and MIGHT squirt on your face if you're not careful. twss.
5. do this filling-method until you start getting new fluid (if blue, you'll know) out of the bleeder... if you swap carefully and replace with the same fluid, you won't have to bleed it much.
6. voila... installed SBK kit. YES that top spring clamp is tricky, but if it was any bigger it wouldn't have enough pressure on the cap end to keep fluid from shaking out while riding. i had a buddy help me slide it onto the cap while i was fighting the pressure. worked out like a champ - about 3 minutes.
7. take pics for the whole world to see how awesome your new agg racing SBK reservoir is. post up on the internet so all can see... then buy.
Agg2001 is offline   Reply With Quote
Old 10-05-2011, 10:15 AM   #2
Ryan5544
Stinks Like Sex In Here..
Ryan5544's Avatar
Bike: GSX-R
Re: Agg Racing, NEW ITEM: SBK rear reservoir kit
Buying this.
Ryan5544 is offline   Reply With Quote
Old 10-05-2011, 10:18 AM   #3
Ryan5544
Ryan5544's Avatar
Bike: GSX-R
If I want to also get some extra tubing, how shall I go abouts placing how much I want??
EDIT.. Never mind.. Just read the disc. and got my answer..
Old 10-05-2011, 10:20 AM   #4
m3lover1
Lead3r of the Triads
m3lover1's Avatar
Bike: 07 Gray R6, 09 Orange R6
YEs!!!!!
Just ordered it along with valve stems!!!! Can't wait!!!
Proud winner of April 2013 ROTM with a bike that no one likes!
I <3 PASSION MOTORSPORTS
Street/Track Build
Ive taken bigger shits than Ricky, but he has personality, so that should count for something......right?
I see my balls are in high demand in terms of cupping
RIP Jason (Snocompton). We will miss you.
m3lover1 is offline   Reply With Quote
Old 10-05-2011, 10:26 AM   #5
Ryan5544
Ryan5544's Avatar
Bike: GSX-R
*Doesn't get reply from Agg in the thread within 2 minutes - Thinks he's ignoring me*
Old 10-05-2011, 10:37 AM   #6
I3eXa
What's an R6? R2D2's bro?
I3eXa's Avatar
Bike: 2000 R6 Champions LE
confused....call but stupid but I don't see the point of this....what am I missing?
Yut Ughhhhhhhhhhh!
I3eXa is offline   Reply With Quote
Old 10-05-2011, 10:38 AM   #7
Ryan5544
Ryan5544's Avatar
Bike: GSX-R
Testicles.
Old 10-05-2011, 10:40 AM   #8
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Thanks again for getting this together Justin. Order placed for 1 setup and 1 set of valve stems with coupon code!
My 02 Thread My 08 Thread Shermoto Racing R6 Levers FREE CLASSIFIEDS!!!!
Ask about:
BMC-Canyon Dancer 2-Motul Specials-Winterization kits/Battery Tenders-LEO VINCE- -STAHLBUS- -WOODCRAFT- -XT-RACING- -FERODO- -BRAKE TECH- -SHERMOTO-
-NGK- -SUOMY- - MOTUL- -EBC- -Pro-Grip-Ohlins and everything else!!
Old 10-05-2011, 10:41 AM   #9
ChiefSmokeDawg
Parts Pimp
Check out the thread
No reservoir = less weight
Also, there is no reservoir to break open and spill fluid on the track.
It looks pimp. It's what all the racers do.
Ask about:
Old 10-05-2011, 10:47 AM   #10
Agg2001
Agg2001's Avatar
add the full kit to your cart, then go back and add however many additional feet of tubing only to it...
boom... lemme know.
and sorry about the 5 minute delay. had to run into town to pick up some shipping supplies for the brake lines going out today.
03-5 R6 Rear Brake Master Cylinder w/ Reservoir - $20 Shipped klr1123 Bikes Parts For Sale 2 01-11-2011 10:26 AM
HRC Rear Brake Reservoir Mod JTolles Appearance and Exterior Mods 39 11-16-2010 09:42 AM
Rear brake fluid reservoir is empty?? signalbobby Garage / Mechanical Help 22 01-31-2010 08:27 PM
Protecting the rear brake fluid reservoir Andrew General Discussions 43 08-12-2008 04:49 PM
WTB: 02 R6 (all right side) clip on, mid fairing, rear set, rear peg, brake reservoir 02 R6 Bikes Parts For Sale 1 12-19-2007 12:27 AM
