09 R6 - neutral switch location and 12V cable : Yamaha R6 : R6 Forum
Old 11-15-2011, 07:29 AM   #1
-mariano-
Hello all
Im trying to install one of these gear indicators:
http://www.ebay.com/itm/Blue-Univers...item3a68ec3971
and to do so I need to locate 2 things:
- where is the neutral light switch? in the older models it is located next to the rear suspension, is it the same in the '09?
- I need a +12V input. Where would be the best/easiest place to get it from? (ie, I wont like to cut any wires). Taking it from the battery is not an option because it will always be on.
I will post the how-to if I can make it work.
Thanks !!!
-mariano- is offline   Reply With Quote
Old 11-15-2011, 07:40 AM   #2
SlowAndOld
SlowAndOld's Avatar
Bike: 2 kawis and a 03 R6
Re: 09 R6 - neutral switch location and 12V cable
Originally Posted by -mariano- View Post
Hello all
Thanks !!!
Usually they are tapped into the harness behind the cluster directions should tell what colors to tap
SlowAndOld is offline   Reply With Quote
Old 11-04-2012, 01:21 PM   #3
animal1000
Live ride die
animal1000's Avatar
Bike: 08
I'm also thinking of getting one of these gear indicators so could anyone tell me were the neutral switch is on a 08+ Thanks
It was like riding an Epileptic fit...
animal1000 is offline   Reply With Quote
neutral switch spikek12 Garage / Mechanical Help 9 03-28-2010 07:46 AM
neutral switch solidgooold Garage / Mechanical Help 1 08-30-2007 10:55 PM
Neutral switch 00R6builder Garage / Mechanical Help 7 06-09-2007 12:51 PM
Throttle Cable Location phatr6 Garage / Mechanical Help 2 07-10-2006 03:04 PM
Is it bad to switch from neutral to 2nd? jonLr6 General Discussions 8 04-20-2006 06:43 PM
