2000 R6 won't rev past 10k : Yamaha R6 : R6 Forum
Old 05-01-2005, 09:18 AM   #1
chubbster1uk
chubbster1uk's Avatar
Hi guys, I have a seriously annoying problem with my uk 2000 R6, it will rev cleanly right up to 10'000 rpm, then feels like it's hitting a limiter and stutters along not producing anymore power, it's does this the same on a standard can or a race can, I am not sure of the bikes history, I have only had it a short while, but it has what Iam sure are standard air intakes and filter.
As you all know 10k is where the fun happens!!
chubbster1uk is offline   Reply With Quote
Old 05-01-2005, 12:30 PM   #2
LuvMyR6
Rossi Is King
LuvMyR6's Avatar
Bike: 2003 Team Blue R6
Images: 1
u might have a fuel delivery problem my buddy has a 02 cbr and he had the same problem i think it was clogged injectors or sumin like that. bring it to the dealer
2003 Yamaha Team Blue R6..."She's Got Balls"...Who Needs A Liter Bike?!
*AGV Rossi Valencia Limited Edition Helmet #79 Out Of 500*
My Bike Does Not Have A Headlight Out...It's Just Winking At You
"Rules Were Made To Be Broken But You Can't Make Broken Rules"
"I Feel Like You Done Left Me But I'm Still Not Alone...I'm A Big Boy Now But I'm Still Not Grown" - DMX
LuvMyR6 is offline   Reply With Quote
Old 05-01-2005, 01:12 PM   #3
jt_tool
the old carburated r6's had fuel pumps too didn't they? i'd check out your fuel filter if neither of these posts help you.
http://www.r6messagenet.com/forums/s...&highlight=rev
jt_tool is offline   Reply With Quote
Old 05-01-2005, 07:59 PM   #4
youryama
I had the same thing happen to me at Texas World back in '02 when I first started racing the R6. The K&N airfilter was installed upside down.
youryama is offline   Reply With Quote
Old 05-01-2005, 08:14 PM   #5
Kelp
Kelp's Avatar
LOL
Kelp is offline   Reply With Quote
Old 05-01-2005, 08:23 PM   #6
youryama
Yeah, what can I say. I was new. It looked right when I put it in you know.
Old 05-05-2005, 11:29 AM   #7
R6racerUT
hard to say what the problem is. is the bike acting like it is running out of gas? is it acting like it is flooded? or is it acting like a rev limiter?
if you arent sure which of the 3, try reving the bike in neutral to see if it will go past 10K. dont do this alot as that is pretty hard on a motor. if the bike will rev past 10K, you at least know that your ECU hasnt imposed a soft rev-limit (this doesnt mean that it still isnt the problem). Make sure that the air filter is clean and not plugged/dirty. This can cause the bike to run too rich at higher rpm/speed and flood the bike. i personally prefer oem filters to aftermarket on R6's, but that is a personal opinion. Also, ensure that the filter does not have too much tact oil on it, as that can also starve the motor for air. check your fuel filter and replace it if it shows ANY signs of being dirty. check your fuel pump to ensure that it is up to snuff. the service manual states how much fuel it should pump in a timed test. be sure it is there as the bike really eats gas at high revs. finally, what condition are your carbs in? when is the last time they were pulled apart and cleaned? if you have run bad gas through your bike or you let it sit for any significant time, your carbs can be gummed.
any and all of these items can cause your bike to stumble at higher rpm's and each needs to be checked. dont just stop at one if it seems like it is the culprit. every spring, my 99 r6 gets her carbs cleaned, new fuel filter, cleaned airfilter, fresh fuel, and fresh oil and oil change before i start her for the first time. an ounce of prevention is worth a pound of cure.
Scott
Madison Racing
MRA/WERA/CCS/MoM 143
pray to god 3 times, then brake
R6racerUT is offline   Reply With Quote
Old 05-12-2005, 07:18 AM   #8
chubbster1uk
Cheers for all the help, on stripping it, the filter is very dirty, there is oil all around the intake of the 1st carb, (left as you sit on the bike) the plugs all look ok apart from the same side as the oily carb, I am replacing the plugs and filter first to see if this helps,
Can't ride at the moment tho as broken my kneecap!!
$3500 for 2000 r6.... more info inside...Is it a good deal? bassfishingboy General Discussions 11 08-15-2008 11:10 AM
2000 r6 grep_rask General Discussions 6 05-27-2005 04:24 AM
2000 R6 TAIL CONVERSION TO A 2002 R1 TAIL OR NEWER VICTOR_A_MAURO Appearance and Exterior Mods 0 04-15-2004 12:04 PM
2000 R6 TAIL CONVERSION TO 2002 R1 TAIL OR NEWER VICTOR_A_MAURO Appearance and Exterior Mods 0 04-15-2004 11:57 AM
rear fender for 2000 r6 quickr6 Appearance and Exterior Mods 8 01-05-2004 08:35 AM
