2000 r6 carb clean help. Where to go from here : Yamaha R6 : R6 Forum
Old 03-31-2012, 09:51 AM   #1
karlo b
karlo b's Avatar
Hey guys. So the weather has been cold and I wanted to clean out my carbs.
Im at this stage. How do I take them apart from the engine?
Where do I go from here
karlo b is offline   Reply With Quote
Old 03-31-2012, 10:37 AM   #2
Shush319
Big ol pile of them bones
Shush319's Avatar
Bike: listed in sig
Re: 2000 r6 carb clean help. Where to go from here
Check out Chief's 02 thread here (lots of pics and write up stuff):
http://www.r6-forum.com/forums/showt...light=chief+02
CCS Racer #379
Bikez:
01' Champions Limited R6 (retiring from racing)
88' GSXR 750 (recently restored)
02' R1 (sold)
07' R6r (race project)
04' Zuma 50cc (have to get around in the pits)
01' XR70R (sold)
??' 50cc air cooled pocket bike (dangerous!)
99' CR125R (sold)
Shush319 is offline   Reply With Quote
Old 04-03-2012, 03:24 AM   #3
-Nix-
I had this issue last week, your sir are at the fun part.
In the picture i attached, you will literally have to go UNDER the carb where the arrows are pointing. There are some VERY small allen wrench bolt about where the circles are. The arrows are where you will enter from with your allen wrench, and the circle is where youll unscrew at. Get a bright light, because they are small. It is a very painful task. But the screws are under it. Took me forever to realize where they were, but im sure you will see them.
-Nix- is offline   Reply With Quote
Old 04-03-2012, 05:56 AM   #4
karlo b
karlo b's Avatar
hey.
yeah i did see some screws in there but was not sure if those will make the carb go loose.
Old 04-03-2012, 05:58 AM   #5
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
hey.
The screws that are easily visible are the sync adjustment screws. It's nearly impossible to see the screws on the boots that are below the carbs
The 02 thread Shush linked is mine and has some helpful pics in there.
CONTACT/EMAIL ME HERE
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
Old 04-03-2012, 06:19 AM   #6
derK
Am I the only one that can't easily see these carb sync adjustments screws? Are they attached to the butterfly valves?
derK is offline   Reply With Quote
Old 04-03-2012, 06:32 AM   #7
ChiefSmokeDawg
Parts Pimp
They are in between the carbs on tha shaft that is attached to the buttefly valves. There is a spring on the screw (sort of). Usually there is also a paint mark on them from the factory to show whether it's been adjusted or not.
Old 04-03-2012, 06:47 AM   #8
derK
I can see them but I can't see the head of the screw unless I rotate the throttle to open the valves a bit. How does Yamaha expect us to sync at idle if you can't even get a screwdriver on without twisting the throttle!?
to the original poster - SORRY for changing subjects for a bit!!
Old 04-03-2012, 06:59 AM   #9
ChiefSmokeDawg
Parts Pimp
I think that yamaha might make a weird screw driver for this!
Old 04-03-2012, 08:14 AM   #10
karlo b
karlo b's Avatar
I will take a look today after work.
What's the best oil for a 2000 R6 (the carb) TUFFY Oil and Lubrication 11 02-01-2014 11:36 AM
New R6 owner...can I clean carb jets without removing carbs? WhyZeeEffAreSix General Discussions 6 03-07-2007 10:03 AM
WANTED: 2000 carb intake trumpets Dolts Bikes Parts For Sale 0 06-27-2006 07:33 AM
2000 R6 carb help sheetone Exhaust and fuel delivery 4 05-12-2005 09:25 AM
carb question 2000 R6 subzero General Discussions 2 05-01-2005 06:09 AM
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
