Blue Gauges mod (change gauge backlighting) : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > How To's...
Old 05-14-2012, 06:10 AM   #1
burnsy180
My R6 eats oatmeal...
Bike: 2008 YZF-R6
Hey guys,I've used several of your How-To's personally and your forum for invaluable advice, so I thought I'd contribute something back!
I did this mod a month or 2 ago but took plenty of pics to help u guys out.
This mod was done on an 08 R6 to change the stock gauge cluster backlighting from red to blue.
I've heard a few guys ask about how long this may take and it really depends. I'm fairly experienced with soldering and circuit boards and it took me (including fairing removal and replacement ~ 40 min) about 3 hrs.Most of the time is spent trying to properly de-solder the lcd screen pins, but i'll get into it none the less.
Tools Required:
  • 8 x Replacement LEDs (4 x for LCD panels, 4 x for tacho, you will need this type of LED (http://australia.rs-online.com/web/p...e-led/6659380/), i'm an aussie, but i'm sure you can find a supplier of similar LEDs elsewhere. Also, when ordering these, make sure you get AT LEAST 224mcd(intensity/brightness), otherwise they will be too dull. Go higher and you can always adjust them with brightness control buttons))
  • Soldering Iron (preferably a soldering station with adjustable temp, but a low power iron with a SMALL tip will do)
  • Thin gauge solder
  • Solder-wick (to remove the existing solder)
  • Isopropyl Alcohol (to clean the board after removal/installation)
Righto, so first step is to get your gauge out.You will need to remove mirrors, windscreen and front cowl. You can just drop the front cowl down and rest it on a towel then unplug and remove the gauge cluster via 3 screws on the back (~ 20 mins)
Next you'll need to remove the gauge casing and needle to expose the circuit board. Place the cluster face down.
Remove all the black screws (11) and remove the back casing.
Lift the circuit board out using the black plug and flip it over.Remove the tacho needle by pulling STRAIGHT up, you can use your fingers or alternatively use 2 teaspoons on either side as levers.
Flip it back over and remove all the other small black screws (13) on the circuit board.
This will remove the black shrouding along the top of the gauge.
Next step is where some of the de-soldering starts.In order to remove the tacho faceplate, you need to de-solder 2 pins sticking through the board for the security/key/flashing red light LED.
For those of you not familiar with solder-wick, simply place the end of the solder-wick on the existing solder, place the soldering iron on top and the solder will melt into the wick and off the board.You may need to cut the used tip of the wick off and re-do this a few times to remove all the solder from the pin/board.
Once both pins are free the gauge faceplate should lift off the board.
Now the real fun begins! This is the most time consuming part. Not hard, just a bit fiddly.
Youll need to de-solder about 16(ish) pins on each side to remove the LCD screens and get access to the LCDs underneath.
(this pic was taken with the pins already removed)
After de-soldering all the pins in the same way as the previous red-light pins, you can check if the pins are loose by grabbing the pin end with some needle-nose pliers and moving side to side.
You'll need all the pins to be loose/separated from the board to lift the LCD screen off.
Once off, should look like this:
NOW you have access to all your LEDs that you want to replace.
(8 total, 2 behind each LCD and 4 behind gauge)
De-solder the LEDs (there is a small amount of solder on each edge, as these are surface-mount and don't go through the board), taking note of the orientation of the LED. LEDs will only work in one direction, so you can test this with a multimeter if you're unsure.
But if it's the same type of led you're fitting the just make sure they're facing the same way.
Before you solder anything back on, give the board a good clean with the isopropyl alcohol to remove the flux (yellowy stuff).
Now it's simply a matter of soldering your new LEDs and the screens back on.
Like I said before, it can be a little tricky as they are small parts. But small gauge solder and a fine-tipped soldering iron help A LOT.
I found the easiest way to get the LEDs back on was to melt a little solder onto the pad where it sits, then hold the led with pliers and re-melt the solder as you place it on the pad.
Clean off the yellow flux after you're done.
Once you're done with the LEDs, place the LCD screens back on and feed the pins through the holes.
Re-solder all the pins back to the board (you will only need a very small 'dab' of solder per pin) to make a good connection.
Also be careful not to allow solder to 'short' any pins together.
Once you re-soldered all the pins on both LCD screens, you can re-attach the tacho and feed the 2 pins for the security light through the board and re-solder.
Once these are done give the board a good clean with the alcohol and simply re-assemble in the reverse order.
All these steps may look a bit daunting but when you break it down it's very simple, just time consuming.
So you can now change your gauges to whatever colour you want in whatever configuration you choose.
ie: blue screens and white tacho etc.
Any questions feel free to ask!
burnsy180 is offline   Reply With Quote
Old 05-14-2012, 06:39 AM   #2
Doc-Ram
I ride with Passion
Doc-Ram's Avatar
Bike: 08
Re: Blue Gauges mod (change gauge backlighting)
nice write-up
and yeah, and welcome to the forum, great first post
Doc-Ram is offline   Reply With Quote
Old 05-14-2012, 06:47 AM   #3
wrestler4life521
Bike: 04 r6 (sold)
You sure beat my first post . Welcome to the forum.
wrestler4life521 is offline   Reply With Quote
Old 05-14-2012, 06:52 AM   #4
burnsy180
Bike: 2008 YZF-R6
Haha yeah, didn't realise I had never actually posted before.
Cheers fellas
Old 05-14-2012, 07:29 AM   #5
burnsy180
Bike: 2008 YZF-R6
Here's a pic of the gauges at night
Old 05-14-2012, 07:32 AM   #6
wrestler4life521
Bike: 04 r6 (sold)
Looks great. Wish this thread was around before I sold the bike.
Old 05-29-2012, 05:14 PM   #7
DubsR6
Bike: 04 R6
Do you know if this would work on an 04?
DubsR6 is offline   Reply With Quote
Old 05-30-2012, 12:46 AM   #8
burnsy180
Bike: 2008 YZF-R6
I'm not sure as I haven't had the chance to pull apart one, but the basis for all models are the same.
All that may be different is the steps to remove the gauges and possibly the type of led to replace.
Everything else should be roughly the same.
Give it a look and see what you need and give it a go!
Old 12-12-2012, 08:49 PM   #9
kent.gaudern
i like this but at night i notice on yours you cant really see the red line, which i guess isnt a problem considering you shouldnt be red lining it, but is that bc the color of the light or the brightness of the light. if i got brighter blue would this show up better? im actually thinking of doing mine white with red needle and blue everywhere else.
kent.gaudern is offline   Reply With Quote
Old 12-12-2012, 09:13 PM   #10
bryan j
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Just some random info. they use red for a reason. It's the easiest color for the eye to pick up in low light. Green comes in second
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
bryan j is offline   Reply With Quote
Just got my blue gauges conversion back from PPC! zeus_r6 Appearance and Exterior Mods 28 05-16-2012 01:31 AM
anyone change the gauge cluster backlights out !? 6spdg37s Appearance and Exterior Mods 2 04-16-2011 04:42 PM
Blue led Gauges Mod R10ER4LIFE Appearance and Exterior Mods 12 09-29-2010 07:25 PM
Finally did the blue gauges cadillacdavid Appearance and Exterior Mods 27 04-02-2009 05:36 PM
Gauge Swap !? 03-05 gauges on 99-02 r6 MorenoR6 Appearance and Exterior Mods 0 05-31-2006 07:42 PM
