HID issue : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Appearance and Exterior Mods
Old 05-28-2012, 10:25 AM   #1
Redlinin
HID issue
I recently just picked up a set of hids from Agg, and they worked perfect the first week. But I came home from a ride and noticed my low beam was out but my high beam was fine. When i turn on the bike the low beam turns on for about a second and then shuts off. Could it be a bad ballast or do I need a relay, or something like that?
Redlinin is offline   Reply With Quote
Old 05-28-2012, 10:39 AM   #2
MikeN02
Mario J's Apple Juice
MikeN02's Avatar
Bike: White Raven R6
Re: HID issue
Check to see if your connections are secure. Where did you connect the ground wire to?
Special Thanks to GIJoe007 for this sig.
MikeN02 is offline   Reply With Quote
Old 05-28-2012, 11:35 AM   #3
saleenbiker
My R6 eats Ninjas.
saleenbiker's Avatar
Bike: '07 R6, '07 Ninja 250
Re: HID issue
you probably need a relay, but double check with Agg he'll know what to do.
saleenbiker is offline   Reply With Quote
Old 05-28-2012, 12:17 PM   #4
mintsoda
:sheep
mintsoda's Avatar
Bike: 07
Re: HID issue
Switch the bulbs and see if your problem moves or stays
Originally Posted by Bpower View Post
You have been reported.
mintsoda is offline   Reply With Quote
Old 05-28-2012, 04:14 PM   #5
Redlinin
Re: HID issue
okay ill switch the bulbs and see what happens, and i guess i can switch the ballasts too and see if thats the issue, but as for relays i havent heard of anyone having to use them on our bikes, someone please correct me if i am wrong
Old 05-28-2012, 04:15 PM   #6
Redlinin
Re: HID issue
i tapped into the stock wiring harness so i would have a clean install and used the factory ground that they used
Old 05-28-2012, 04:46 PM   #7
OhioYJ
OhioYJ's Avatar
Re: HID issue
Sounds like a bad ballast. I haven't heard of anyone needing a relay with the standard 35 watt HIDs. I got mine back when Krypton was first getting started, so mine have been in for a while, no relay.
As already mentioned you just need to switch parts around to verify which part is the problem. Also double check all your connections just to be sure.
OhioYJ is online now   Reply With Quote
Old 05-28-2012, 05:34 PM   #8
Agg2001
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
Re: HID issue
it sounds like you're not getting enough steady juice... so i'd START by telling you to run a relay. at least on the lowbeam side. IF the problem persists, let me know, and i'll get ya squared away.
Agg2001 is offline   Reply With Quote
Old 05-29-2012, 07:54 PM   #9
Redlinin
Re: HID issue
tried to run a relay, and that didnt help, switched the lights that didnt work, switched the ballasts and the problem followed to the other headlight, so it has to be a bad ballast i suppose.
Old 05-29-2012, 08:10 PM   #10
jwxfd
190rwhp......:eek5
jwxfd's Avatar
Bike: 2011 S1000RR, 97 CR500
Send a message via Yahoo to jwxfd
Re: HID issue
Yup, bad ballast...shit happens
Sig courtesy of the man himself: GIjoe007
jwxfd is offline   Reply With Quote
HTML code is On
HID issue SLR6 Appearance and Exterior Mods 5 04-26-2011 09:51 PM
03 r6 and pc3 issue ttc Exhaust and fuel delivery 0 02-07-2011 10:02 PM
2CT ISSUE, anyone else? fasttoys1 Tire Tech Talk 15 05-21-2008 04:13 PM
Oil pan issue! Brad Garage / Mechanical Help 7 04-06-2006 05:57 PM
A Issue R6KIDD General Discussions 5 04-02-2005 04:11 AM
