From the original seller of these high quality valve stems
90 Degree Drop Forged Aluminum Angled Tire Valve Stems in various colors...
Available in:
-Black
-Red
-Silver
-Gold
-Blue
Available in both 11.3mm and 8.3mm
For our bikes and most Japanese bikes you will need the 11.3mm but if you have Carrozzeria, Galespeed, OZ, Marchesini, Marvic and BST wheels you will need the 8.3mm ones.
These are the same valve stems which come from the factory on the fancy italian bikes (Ducati, Aprillia, etc) and many MotoGP, WSBK, Moto2 teams use these valve stems.
Generally race teams like to run a different color valve stem than the wheel so that they can easily spot the valve stem.
They are made in Italy and are
the same valves which are sold under the Ariete brand for much more.
What they do?
-Easier to check pressure and fill tires (specially on the front)
-Lighter than rubber stems - they weigh in at 11 grams each
-They are reusable, no need to replace them like rubber valves with each tire change
-Fixed to the wheel with a locking nut, can't bend, or be expelled from the wheel
-The angled quill reduces the effect of centrifugal force, which tends to fling the valve core outwards in a conventional valve, leading to loss of pressure in tires.
Installation
Torque the locking nut to 7-10 Nm
How much?
$22.05 shipped for the pair! (USA & Canada)
add $3 for international shipping outside of USA & Canada
How to purchase?
Use the specific
buy now button that corresponds to the size/color of the stem you would like.
Typical delivery times are around 4 to 10 business days.
Simple payment, just use the
BUY NOW button below to purchase your set!
11.3mm Black - Pair
11.3mm Silver - Pair
11.3mm Gold - Pair
11.3mm Red - Pair
11.3mm Blue - Pair
8.3mm Black - Pair
8.3mm Silver - Pair
8.3mm Gold - Pair
8.3mm Red - Pair
8.3mm Blue - Pair
As always, if you have any questions you may PM me any time!
