Damper, tires, or... : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 06-17-2012, 09:47 PM   #1
R6_Dude
R6_Dude's Avatar
...Just the way it is.
06 r6
When I make a normal right turn for example, I feel like the handles bars automatically turn in even though I am trying to counter steer.
Is this because of my tires? Do I need a damper To keep the steering a bit stiffer? Or is it just the way it is.
R6_Dude is offline   Reply With Quote
Old 06-17-2012, 09:57 PM   #2
natedogg624
Re: Damper, tires, or...
slow turns it's the way it is <20
check tire pressure.
stop overthinking it.
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is online now   Reply With Quote
Old 06-17-2012, 10:29 PM   #3
R6_Dude
R6_Dude's Avatar
That's what I thought but just thought I'd ask. Plus I was thinking somebody might give me an excuse to buy a damper
Old 06-18-2012, 01:23 AM   #4
R-Silaxin
Track=Cocaine
R-Silaxin's Avatar
Bike: 06 R-6 Deathraven
Old 06-18-2012, 01:26 AM   #5
Cj 98
Hard Parked
Cj 98's Avatar
Bike: 05 R6
Send a message via AIM to Cj 98
Just let it happen.
Sig by GIJoe007
BUY MY R6!
It's the fastest color.
2nd Gen Parts:
Buy it Here!
Cj 98 is offline   Reply With Quote
Old 06-19-2012, 04:28 PM   #6
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
you only need a damper if your lifting the front wheel on the gas exiting a corner.. the wheel sets down slightly off line from your direction, and it may help it from violently snapping into line. Or, if your racing and you end up off track and coming back on, the damper helps avoid the dreaded "tank slapper" .
For street riding, in my opinion, it does nothing more than look cool. Too many riders crank them up super stiff trying to overcome a suspension issue that should be looked into instead of cranking up the damper.
Have you checked your steering head bearings? that would be a place to start, as well as what others have said about tire PSI, and possible cupping of your tires.
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 06-19-2012, 04:44 PM   #7
bryan j
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
How good is your front tire? Ride my friends bike with a worn out front abd it felt that way.
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
bryan j is offline   Reply With Quote
Old 06-19-2012, 05:25 PM   #8
HIS OWN 6
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 97 GSXR 750
Countersteering is what initiates the lean to make the bike turn, but as you turn the bars actually to turn to the direction you're going.
HIS OWN 6 is offline   Reply With Quote
Old 06-19-2012, 05:30 PM   #9
bluerebel
Sometimes..........
bluerebel's Avatar
Bike: 2012 R6
what color power band do you have on it?
bluerebel is offline   Reply With Quote
Old 06-19-2012, 05:34 PM   #10
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
efinitely check your tire pressure. On a soft carcass tire you will get the sensation that the bars turn the direction you are going. Try going out on cold tires but the pressure is set for off the warmers and you will know this.
Check those pressures! Under 20 MPH, the bike isn't a great maneuvering machine for me at all tho. I'll use the throttle clutch and back brake at low speeds like Nate said. She wants to tip in, let the clutch out a bit and keep er up, etc..
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
Harris damper kit....Need damper size confirming!! R10ER4LIFE Garage / Mechanical Help 2 07-21-2011 04:29 AM
Tires slipping.. Noob mistake or tires cooked? swiftaudi Track Tech & Riding Techniques 13 07-16-2009 02:27 PM
33" Tires FS..NOT bike tires (obviously) barlowrs Bikes Parts For Sale 0 03-11-2008 04:06 PM
race tires or street tires(pilot power) bizie General Discussions 16 09-18-2006 02:36 PM
buying tires in pairs vs. single tires the-new-guy Tire Tech Talk 11 03-25-2004 03:21 PM
