Where to buy individual valve shims? : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 07-12-2012, 09:23 PM   #1
bryan j
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
I need a few shims and paying 80 bucks for a kit of 50 shims seems a little steep. I tried search and only found kits. Any place I can buy a individual ones?
Thanks
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
bryan j is offline   Reply With Quote
Old 07-12-2012, 10:27 PM   #2
DTcrew4
Crew for Life
DTcrew4's Avatar
Bike: 2007 HighSided R6
Re: Where to buy individual valve shims?
Do you already know what size shims you need?
I suppose if you do, then you could go to your local dealer/service department.
DTcrew4 is offline   Reply With Quote
Old 07-12-2012, 11:12 PM   #3
Mork201277
online
Mork201277 is offline   Reply With Quote
Old 07-12-2012, 11:16 PM   #4
redwood650
Will work for track time
redwood650's Avatar
Bike: 04 R6, 06 CRF250X
Dealer can order single shims for you as long as you know what size you need. As mentioned already
redwood650 is offline   Reply With Quote
Old 07-13-2012, 12:56 PM   #5
bryan j
pin it to win it
bryan j's Avatar
Alright cool.
now 2 more questions.
So say the shim is a .155 and my clearance is .13. I want the clearance a lil more so I would need a .150 shim correct.
And while I'm doing this is their anything else I should replace like piston rings, cam chain, or tensioner
Old 07-13-2012, 01:21 PM   #6
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Is that exhaust or intake clearance? Intake spec is .12-.19 mm, Exhaust spec is .16-.23mm. If it is intake, it is in spec (the lower end but in spec)
But to answer your question, if the shim says 155, then it is 1.55 mm thick. If you measured .13 mm, then a 150 (1.50 mm) shim would give you another .05 mm clearance theoretically so .18 mm. I say theoretically because worn shims are rarely the thickness they say, because......well, they are worn. So measure it with a set of digital calipers. I would guess that your 155 might actually be 1.53 thick. In which case putting a 150 in it would give you .16 mm clearance.
As to what else you should replace (Assuming you are around 20-25K miles). Piston rings would require tearing down the engine. Cam chain on some engines can be fished out without splitting cases, but it is a bitch and I don't know if it can be done on the R6....never tried it. Replacing the cam chain tensioner with a manual one would not be a bad idea, but not necessary.
Dear SpeedTV,
I, for one, will be extremely happy when you finally make the transition to a main line sports channel.
.....it will mark the end of your network pretending to be a motorsports channel.
Thank you for finally realizing what the rest of us already knew.
8Ball is offline   Reply With Quote
Old 07-13-2012, 01:25 PM   #7
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
Oh, and another thing. when you figure out what sizes you need. Go to your local shop and talk to the mechanic, and see if they will swap out the ones you need in exchange for yours.
Dear SpeedTV,
Old 07-13-2012, 02:05 PM   #8
bryan j
pin it to win it
bryan j's Avatar
Ok thanks man. My intake are all at .13 so I figured it wouldn't be a bad idea to go ahead and shim those. The exhaust are .15 so barely out of spec.
Also the cam lobe on cylinder 4 looks a lil worn compared to the rest, so that worries me a bit. Idk If I should replace it or if its fine. Kinda just looks like the coating on the lobe has wore off.
I don't mind pulling the head and doing the rings if its a good idea. This is my first street bike and I'm not sure how long a top end last. I know when I would do valves on my mx bikes I would do rings and cam chain also.
Old 07-13-2012, 02:27 PM   #9
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
Download the service manual (if you don't have it already). It gives you the measurements to check the cam lobe. You will need to remove it anyways to replace the shims.
How many are out or close to out of spec? If you need more than 10, I doubt that the service manager would let you do a free swap out, and the individuals are gonna cost $3-5 each, so you'd be better off buying the kit.
Finally, the maintenance for dirt bikes is vastly different than street bikes, which are designed to be more reliable for longer maintenance intervals. And the cylinders are part of the crank case on the R6, so piston rings mean splitting the cases. Unless you are racing, you are a loooonnng way from needing to do that work.
Dear SpeedTV,
Old 07-13-2012, 02:45 PM   #10
bryan j
pin it to win it
bryan j's Avatar
Let me see what specs I wrote down. I have the Manuel but my computer crashed a few months ago.
Intake:
.13 .13
.13 .13
.13 .13
.10 .10
Exhaust:
.13 .13
.15 .15
.15 .15
.13 .13
So for sure I need 2 intake and all 8 exhaust. Might as well do all 16.
Intake should be .12-.19 so I'm aiming to get them at .15
Exhaust should be .16-.23 so .19 is my goal.
Looks like I might end up buying a kit. I just hope I won't need more than 3 of a certain shim size since all the kits I've seen only carry 3 of each size.
And ill skip the rings. It's way to much of a hassle splitting cases.
valve shims help Basket Case Garage / Mechanical Help 4 09-12-2012 05:51 PM
valve shims and buckets. gamma1 Garage / Mechanical Help 4 05-05-2011 04:30 PM
Valve Shims In San Diego Area mxgman General Discussions 3 12-26-2009 11:39 AM
Valve Shims In San Diego Area mxgman Garage / Mechanical Help 0 12-26-2009 12:35 AM
How Can You Tell If You Need Valve Shims When Doing A Valve Adjustment? blk600cc General Discussions 12 05-10-2009 10:20 PM
