Bike won't start...another one. : Yamaha R6 : R6 Forum
Old 09-30-2012, 11:17 AM   #1
topherchris
My R6 is trouble.
topherchris's Avatar
Bike: 2007 R6 - 2006 R1
Was running fine to ride over to tech and fill up, I pulled away and it started sounding louder and lower, sputtering a little bit. The bike stalled, restarted then did the same thing and stalled. It won't start now and is throwing a Code 46, it will crank all day though and very once in a while make an attempt to start. I've been searching and can't seem to find anything relevant. Quick replies are appreciated, I'm wasting track time.
topherchris is offline   Reply With Quote
Old 09-30-2012, 11:21 AM   #2
topherchris
My R6 is trouble.
I unplugged the PC3 thinking that could be the problem...no cigar.
Old 09-30-2012, 11:29 AM   #3
topherchris
My R6 is trouble.
Also tried push starting...nothing.
Stator tests fine, battery voltage is fine also.
Old 10-16-2012, 05:51 PM   #4
topherchris
My R6 is trouble.
Changed the tank and fuel pump out, didn't put gas in or try to start...still throws code 46.
Old 10-16-2012, 05:58 PM   #5
yuengling910
Late Breaker
yuengling910's Avatar
Bike: 07 R6S
Re: Bike won't start...another one.
Is the fuel pump getting power?
yuengling910 is online now   Reply With Quote
Old 10-16-2012, 06:01 PM   #6
topherchris
My R6 is trouble.
Yes, I can hear it.
Old 10-16-2012, 06:38 PM   #7
yuengling910
Late Breaker
Bike: 07 R6S
Checked fuses and throttle body electrical connectors?
2nd gen manual says code 46 is improper voltage to FI system relay. Not sure if it's the same on 3rd gen.
Old 10-16-2012, 07:04 PM   #8
topherchris
My R6 is trouble.
Yep...everything checks, I'm at a complete loss. Which is the FI relay?
Old 10-16-2012, 08:30 PM   #9
toysareforboys
Two Bro's=ORGASM *nohomo*
toysareforboys's Avatar
Bike: 07 R1
When you say you disconnected the PC3, did you physically remove it and re-connect everything like stock?
Do you have your service manual? http://ecuflashking.com/r1/manuals/
It goes into detailed tests for the fuel injection system.
-Jamie M.
07 R1 - Flash tune'd, A&R Race Baffles with Akrapovic Y Pipe (wrapped in DEI Titanium header wrap), Renthal MX Kevlar Grips, HVMP Extra Heavy Weight bar ends, Saddlemen "Tech" seat (memory foam + gel), Skeen Racing Extended White frame sliders, Shermoto Levers, Proton flush mount front signals, BMC race filter, Elka Stage 4 adjustable shock, iPod 4th Gen with Harry's Lap Timer Pro with Emprum UltiMate 5hz GPS and Ram mount, 190/55 Bridgestone S20's, Garmin 2595LM GPS in RAM stem mount, MikeyMoto Ultralight rear rotor, Ultra high power LED running lights, trimmed ebay fender eliminator, Shorai LFX14A4-BS12 ultralight battery, Fren Tubo Type 4 CF lines (front and rear), Vesrah RJL front pads, Ferodo Sinter Grip ST rear pads, Amsoil MCF full synthetic oil, Amsoil EA15K13 car oil filter, Wurth HHS2000 chain lube, Shell 91 octane NO ETHANOL fuel ONLY. Coming soon: Race Tech fork kit, EK MVXZ 520 chain, Drive Systems USA Superlite Steel rear sprocket (+2/47t), Driven drilled steel front sprocket (-1/16t), will try to reach top speed of 305kph/190mph.
toysareforboys is offline   Reply With Quote
Old 10-16-2012, 11:33 PM   #10
topherchris
My R6 is trouble.
Yes I completely disconnected it and hooked it up OEM, I think it was actually your reply to a thread where that was the cure that prompted me to do that! I'm going through the manual now, I just swapped out the regulator and still 46.
Help, bike won't start xracer Garage / Mechanical Help 6 05-20-2012 01:32 PM
Bike won't start, or will barely start but dies tkc Garage / Mechanical Help 13 10-12-2011 01:35 PM
Bike will not start Riztnack Garage / Mechanical Help 5 04-02-2010 01:53 PM
Bike Won't Start jmk1223 Garage / Mechanical Help 10 03-27-2010 10:11 AM
Help new bike won't start R6_AT_Kobra General Discussions 10 03-05-2006 06:21 AM
